I haven't even gotten to that step yet...I just put the fly back on...snuged-up bolts...went to torque the bolts down and needed to turn the fly for clearance (from balancer) and it wouldn't turn.
The block plate does go on firsta nd then the fly...smooth side of fly is facing towards the trans.
The few people I've talked to I know who are wrenches...keep telling the fly bolts are too long and preventing the crank from turning, but their the factory bolts that have been in the truck all along...I'm thinking a couple of the bolts require washers on the backside...?
First, let me thank you for your time on this...The block plate is on first (up against the block), but you could bolt the fly to the crank without it.
I'm not a mechanic, just a guy who may be is a bit more mechanically inclined then some. Also, s I'm working on my back in a cold parking lot w/little to no-clearance...I wanted to troubleshoot a bit, so I know what to look for LOL
