T-18 Transmission Fluid
Old 11-11-2014, 05:26 AM
Sean_Memphis's Avatar
Sean_Memphis
Sean_Memphis is offline
Thanks, I'll give it a try!
Old 11-11-2014, 10:04 PM
Sean_Memphis
Apparently, after doing a bunch of research I have an NP435. When trying to get my dogs aligned and get the top cover back on, the shifter popped off and jacked-up my retaining cap...now I need to get a new one of those.
Can I still align the dogs the same way though??
Old 11-11-2014, 11:49 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
Everything still applies.........but with an NP435, you don't have to worry about losing the 1/4" pin.
Your trans is a bit more fiddly to get the selector forks into place in my experience, mainly reverse.
Also pushing that shifter retainer down & twisting it into place isn't easy under the dash either, but.......both jobs are character-building
Old 11-12-2014, 12:03 AM
Sean_Memphis
Yeah, the whole changing the clutch job...has been one big mess from the beginning. The retainer cap breaking, was just one more thing.
Old 11-12-2014, 05:35 PM
Sean_Memphis
I was able to find the retaining cap at my local pick-n-pull. But, getting everything lined-up is kicking my ***...I guess I got the shifter forks in neutral, but I'm not sure about the trans gears :?
Old 11-12-2014, 11:35 PM
Ken Blythen
Even with the trans out on the floor it's not always easy getting all three forks engaged, with an NP435. I don't remember having much problem with T18/19's.
It's just perseverance that will get it.
If it helps, you can measure the spacing between the forks (when in neutral), then check that the gears are spaced exactly the same; but reverse is still difficult to engage when you can't see in there properly.
Blurry94
11-22-2013 09:53 PM
evans213
01-28-2011 09:55 AM
racsan
Oil & Lubrication
10-09-2007 12:22 PM
86diesel-
03-23-2006 07:07 PM
orange peel
10-02-2003 10:32 PM
Quick Reply: T-18 Transmission Fluid
