I may need a bracket, from where the parking brake attaches to the underside of the dash. apparently the PO of my truck cut it in half, so when I apply the parking brake, it just bends to the side and doesn't engage fully! I'll take a pic during daylight!
Kyle, they just snap off from vibration.
I've welded mine back together.
Thought I'd buy a new one, then had to weld it also.
Finding one from an automatic truck -where the owner never used the parking brake- might be your best option.
(better than $230 from LMC, anyhow...
Mines broke right around the very start of the dash under the wheel, its such a clean break it looks like a cut! I should use it as an excuse to go buy a welder finally, Jim!
Keep going, guys. I have an '84 F150 that is being scrapped due to a bad frame. If Gigomags05 doesn't have it on his '82 maybe i have it on my '84. Better to an FTE member than the scrap yard.
By the way, my '84 has 9 inch rear end with 3.55 LS gearing. Anyone close enough to KY to pick it up, shoot me a PM and lets make a deal.
If either of you has an instrument cluster with the tach and gauges instead of idiot lights let me know. I also could use an intermittent wiper switch. I need them for my 84 250. Thanks
Edited to add: I would also love the wiring harness and fixture for an underhood light, if you have it.
Reason: add info
I have an instrument cluster with gauges, but it does not have a tach. It is from an '84. Intermittent wiper switch may be a possibility too. Let me know if you are interested.
