C8000 W/3208 Need Fan Clutch and Fan
Hi
I have a 1988 C8000 with CAT3208 turbo. Unfortunately the fan clutch broke apart without warning, also damaging the radiator and fan.
The radiator may already be found, still need to verify, or it could be re-cored, which is costly these days.
Please contact me if you have any of these parts new or used to sell.
Radiator (don't have p/n )
Fan clutch : E7HTSA 196568 J2295 000039
Fan: E2HT AC 917110M83 (it has 7 blades)
I tried to post this in wtb but could not. Probably have a better chance of success in this section anyway
Thanks
Gil
Thanks
Gil
The radiator may already be found, still need to verify, or it could be re-cored, which is costly these days. Please contact me if you have any of these parts new or used to sell.
Fan clutch : E7HT SA 196568 J2295 000039
ID number: E7HT-SA = Ford part number: E5HZ-8A616-A .. Fan Clutch / Obsolete
I wasn't able to find either of these parts NOS (New Old Stock). Contact: Job Lot Automotive (joblotauto.com ~ 718-468-8585) in Queens NY - They specialize in BIG Ford Truck obsolete parts.
Note: Call between 8:30 AM - 4:30 PM EST .. otherwise, they don't answer the phone...so you have to leave a message.
btw: Where do you live in CA? There are a coupla sources here in L/A that may have these parts.
C. W. Carter Co. & Franklin Truck Parts may also have the parts. Carter is located in L/A .. Franklin is located in the City of Industry, just north of the 60 freeway.
You should also check w/a Caterpillar dealer, as the parts may be available from them.
steve340
05-10-2014 07:20 PM
TURBOSCHILZ
18
02-24-2014 10:04 AM
