77 Hi boy turn signal fuse
Old 10-19-2014, 09:18 PM
WildF4u's Avatar
WildF4u
WildF4u is offline
Hello there,
Wondering if anyone has come accross this problem. The turn signal fuse keeps burning out after taking some turns. I have used the higher amp fuses the problem is I can't use too big else they don't fit on the slot.. Any ideas how I can fix this?
thanks
Old 10-19-2014, 10:40 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Received 3,352 Likes on 2,494 Posts
Yes find out where the hot wire you have is that is rubbing/had a rubbed/chaffed spot or getting or has gotten burned on the exhaust manifold or exhaust system and is getting grounded out.
Mice chew on wires too.....take steering wheel off and look at t/s switch for a broken wire or plastic housing.
Just putting in a bigger fuse is NOT fixing the problem.
Old 10-20-2014, 09:50 AM
WildF4u's Avatar
WildF4u
WildF4u is offline
Thanks I will try that
Jordan M
09-07-2010 06:47 PM
Taters
01-01-2010 11:26 PM
Six Niner
07-26-2004 05:04 PM
odie780
Electrical Systems/Wiring
10-16-2002 10:43 PM
cbpldc
Bronco II
02-24-2002 07:18 PM
Quick Reply: 77 Hi boy turn signal fuse
