Rear Located Gas Tank
Received 4,135 Likes
on
No, actually the picture is deceiving. From the back of the truck, it doesn't hang that low. The bed wood is flush with the tank and only has about a 1 inch clearance between the wood and tank. I used a marine gas filler that was exactly one inch and worked nicely. I guess if you raised the bed floor, it would be possible to mount above the frame, however this is the way the instructions state. I'll try to post a pic of the rear of the truck, you'll see what I mean.
on
the only problem with mounting above the frame is if you have a problem with the tank... you'd have to remove the bed wood or the rear end of the bed to remove the tank or repair it... hanging under the frame is the best way
john
john
John is correct! In the event I would have to remove the gas tank, it would be easy versus having to remove the bed wood, etc. Here is picture (not a great shot) but you can get an idea of what the tank looks like from the rear. Several people paint the tank flat black which hides it even better. Personally, I like the look of the tank.
With the rear mounted gas tanks, I see that most (if not all) the tanks hang below the frame. Does this interfere with the original exhaust system? If so, is a custom exhaust needed or can the tailpipe just be lowered slightly to avoid the tank?
Also, if using the original gauges (in my case 1950), what do I need the empty and full resistance readings to be in order for the gauge to work properly?
I believe that most if not all rear mounted gas tanks will challenge locating a stock exhaust and many other custom exhausts. I suspect that a majority of those with rear mounted tanks in bonusbuilt F-1's end up with a side exhaust. Rear mounted tanks want the same "real estate" that the exhaust wants. That is one reason that I stayed with a stock tank.
I still am not sure how to deal with:
1) The sending unit issues when using a Chevy tank with our stock gauges.
2) The OEM tailpipe
3) Any other issues that I currently haven't thought of yet.
Thus, I am asking if anyone who has already done this mod to fill me in on what I will face to make this work. At this point, I can still go either way. My biggest reason to remove the interior tank is to get a little additional room for the seats. Getting rid of interior fuel and the possible fumes would be a bonus. If I believe it is more trouble than it is worth, I'll purchase a new OEM tank and go that way which is what I believe Bill is telling me.
#28
There was a thread about this a couple of days ago, but I used one from Tanks Inc. It's universal tank which is smaller than some of the others have posted about but it fits very well. Here are a couple of shots of it. I have to fab the frame around it and the filler kit, apron and cap, came the same vendor. Get it out of the cab. My 2cts
