'97 f-250hd 5.8l replacement timing cover
Replaced the water pump and now have a mysterious leak that's pooling coolant right above the new pump. Figure the timing cover got tweaked when breaking the pump bolts loose (fortunately none of them sheared).
I've heard that it's best to get an OEM timing cover (vs discount auto store brands) so as to minimize the chance of fitment and leaking issues, so I was wondering if this Ford Racing cover would work well. Should I be replacing the timing chain and gears while I have the cover off (277k miles)? Thanks for any advice.
Not sure what you did to get the pump bolts out, if basically unscrewed em IE; you didn't have much trouble didn't beat on em? It probably just needs a new gasket between the cover and block now, nothing wrong with the cover it has on it.
Not uncommon/unheard of for the timing cover gasket to spring a leak after disturbing things by changing the pump mounted in the front of it leaving it in place.
The reason I wanted to replace the cover was I'd heard that rotting coolant passages could cause it to leak even with a new gasket.
I'm planning on using Permatex Right Stuff to make gaskets for everything, I learned my lesson the hard way with the water pump and thermostat gaskets not sealing right with the included paper gaskets. I cleaned all the surfaces off, removed the premade gaskets, and used a thin bead of the permatex, which eliminated all the leaks I was having with the paper ones.
Treacy
07-25-2019 12:56 PM
Mbizzal
22
03-11-2019 11:33 AM
fightlivefree
18
07-27-2013 02:17 AM
