custom shelves for the cargo area?
Old 11-08-2014, 11:04 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
Originally Posted by robert_l_ross
Moving the drawer thread so it won't hijack the OP's request:
https://www.ford-trucks.com/forums/1...l#post14801777
Oh no problem, i dont mind. I'll check out ur new thread!
  #32
Old 11-17-2014, 11:25 AM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
Progress...this is in the other thread (not sure if folks subscribed to that one).
Made one drawer larger to hold a rifle Pelican case:
  #33
Old 11-17-2014, 06:20 PM
Magnus E's Avatar
Magnus E
Magnus E is offline
Simply awesome!
  #34
Old 11-20-2014, 01:56 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
Looking great!!
  #35
Old 11-20-2014, 02:53 PM
robert_l_ross
Thanks!
Still need to swing by Fastenal to get some of the right size bolts/nuts.
Now that I have the L channel and measured out the larger drawer correctly, there are some new measurements:
^^Shows the left drawer at full extension (40" with the slides I used).
Thinking of adding 1.5" flat aluminum strip to the underside of the drawer top rails. Should hang over about 5/8" of an inch. This will let me slip in 1/2" ply and make the tops of the drawers so I can use them to write on, reload clips, whatever.
Thinking if I cut two sections just under 2', I could keep them at the 'back' of the drawer when not in use, then pull one out and make the drawer into a surface.
  #36
Old 11-22-2014, 11:53 PM
robert_l_ross
Progress...and setbacks.
So I have about 2/3rds of the base frame done...but a change to the plans that I didn't account for when cutting left me with a lot of excess, so I'm a few lengths short...so I'm on hold until more frame sections arrive.
So far I've attached the right and center sections of frame, the cross members to those sections, the uprights, and the right (larger) drawer.
Bottom frame laid out...
T nuts through the bottom of the base to anchor the base frame to the base...
Drilled and installed the uprights...then mounted the slides...
Added the L channel and mounted the drawer:
Testing the slides:
...so now I'm waiting on the top drawer frame sections:
...and a few more lengths of QuickFrame and I'll move on to the drawer faces and handles/latches.
  #37
Old 11-23-2014, 01:22 PM
ghglenn's Avatar
ghglenn
ghglenn is offline
Well done. Any idea of weight savings? I need to fab a drawer system as well.
  #38
Old 11-23-2014, 04:30 PM
robert_l_ross
If I had to guess I'd say 30/50% weight savings over the wood and super-strut of the first iteration. I'll try to weigh the components I removed from the old box and the new one to get an accurate idea.
  #39
Old 11-23-2014, 05:44 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
Looking good Robert! The alum tube and connectors really make for a clean looking setup, and your work is well thought out and executed, quality job all around I'd say.
  #40
Old 11-24-2014, 12:36 PM
robert_l_ross
Thanks Tom! I'm very excited to wrap it up...now that I'm getting closer it's making me crazy to see it in the garage every day and not be able to finish it until those extra pieces come in.
While I wait for the materials to arrive, I'm going to fab up some drawer faces from corrugated plastic to figure out how I'm going to mount the handles, as well as dry-fit it in the back so I can work out how I'll mount the bottom panel to the floor of the truck.
I'm thinking of using the 4 tie-down points on the floor as well as using the rear seat mounts. The tie-down points should be simple...just get longer bolts of the same size the existing ones are. The seat mount points might be a bit tricky since there is very little clearance between the bottom of the frame and the bottom of the drawers.
  #41
Old 11-24-2014, 07:05 PM
ranagent's Avatar
ranagent
ranagent is offline
I'm about done with a smaller drawer unit, it worked great to replace the tie down bolts with longer ones. They are a 6mm bolt.
  #42
Old 11-26-2014, 12:14 PM
robert_l_ross
Thanks!! I'll be taking one off tonight and seeking it out...
  #43
Old 12-07-2014, 12:54 AM
robert_l_ross
Wish I could post photos of today's progress, but the albums won't let me upload or create new albums!
Let's try this:
Lower frame complete, uprights and slides attached...
Top frame pre-assembled...
Full frame attached to the base wood...
Reinforced the 2nd narrow drawer...
Bottom in the narrow drawer...some decent weight in it with the tool box...
Wide (right) drawer...front support added, bottom added...
Side sheeting applied to one side...ran out of rivets though.
Drawer diamond plate with latch inserted...will have to rivet the face to the drawer front though.
I'm doing first aid on a marathon route tomorrow, but should be able to make some additional progress afterwards.
  #44
Old 12-07-2014, 06:48 AM
Vince79vette's Avatar
Vince79vette
Vince79vette is offline
Looking good man. Getting close to poping it in the ex
  #45
Old 12-07-2014, 09:56 PM
robert_l_ross
Now it won't even let me use a third party vendor to host images...so I guess no more photo updates...WTF?!?!
Quick Reply: custom shelves for the cargo area?
