cruise control not activating
Old 10-12-2014, 08:42 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
The cruise control isn't activating on my 2000 X. The light will come on, on the dash but it never sets. Are there any common issues with this system and is there anything specific I can check?
Old 10-12-2014, 08:57 PM
Ultraboy's Avatar
Ultraboy
Ultraboy is offline
same problem here!
Old 10-12-2014, 09:01 PM
nojoke327's Avatar
nojoke327
Well hopefully we can both get some answers then
Old 10-12-2014, 09:48 PM
Lance Helmert's Avatar
Lance Helmert
Lance Helmert is offline
Ours quit also. I found some old threads. If the horn doesn't work either, it's probably the clock spring in the steering column. It could also be the switches in the steering wheel, a pressure switch on the inside front of the master cylinder, or the brake switch on the brake pedal.
Old 10-12-2014, 10:09 PM
nojoke327's Avatar
nojoke327
I've read some threads about that too but in most of them the dash light wouldn't come on. Mime does come on. I'm definitelly not ruling those things out but I'm wondering if it could be something else
Old 10-19-2014, 07:25 AM
Ultraboy's Avatar
Ultraboy
Ultraboy is offline
Given that the light comes on, that should narrow down the prob. OP, did u get yours fixed?
Old 10-19-2014, 07:33 AM
nojoke327's Avatar
nojoke327
It would narrow it down if I had any idea where to start looking. I've seen almost no info on my issue. There is plenty of info out there like mentioned above, about if nothing works but wothy light coming on I can't get any straight answers
Old 10-19-2014, 07:35 AM
nojoke327's Avatar
nojoke327
Any help to a useful link would be appreciated. Maybe I'm searching wrong
Old 10-19-2014, 08:17 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Plug "speed control diagnostics" (include the quotation marks!) in the SEARCH box above. Plenty of previous threads about this issue if you know how to find them. Substitute the word "cruise" for "speed" for more results.
The speed control system is the same between the Super Duty and the regular F150 series of this era, so do not restrict your research to only the Excursion forum.
Old 10-19-2014, 09:08 AM
nojoke327's Avatar
nojoke327
Thank you. I'm really horrible at searching for stuff. That one word speed vs cruise I'm sure has been screwing up my searches.
Old 10-19-2014, 09:44 AM
projectSHO89
Most likely, it was the lack of the quotation marks. They force the search engine to look for an exact, complete text string instead of just one or more of the search keywords.
Old 10-19-2014, 03:30 PM
Forest's Avatar
Forest
Forest is offline
Do you have electrical schematics? On my 2007 E-450 (motorhome), the cruise also quit. Schematics showed I had a pressure switch and a clock spring as suspects. Tested pressure switch--bad (open). Replaced and I'm back in cruise mode.
Old 11-22-2014, 01:45 PM
itselliot's Avatar
itselliot
itselliot is offline
Excursion Cruise "out of Control"
Hi Guys,
Just got here due to my new to me 2002 X having the obvious problems.....
Let me say that there are way too many threads separately posted about the cruise.......Can the Moderators possibly put them in a grouping???
What I have found in the first 2 days of chasing this gremlin.
The recall is a very poor "fix" by Ford to stop fires/meltdowns caused by a poorly designed pressure switch located on the Master Brake Cylinder.
When the switch fails fluid leaks out into a hot 12V circuit.......the "fix" was to fuse the circuit..........(they SHOULD have improved the switch itself!)
Anyway, temporary jumper in the harness bypasses the pressure switch and will give you the answer to the question of bad switch? Bad recall harness? And bad fuse?.......Question here is WHY!!!?? did they put a fuse in line and then say on the tag,....not serviceable?? Are fuses not meant to be replaced?
Also found after looking at a wiring diagram that pressing the "on" and "coast" at the same time is "supposed" to blow the horn by design.
OK, but ...well whatever.
In order to keep looking at more threads, just scroll to the bottom and open the listed threads in a new window(right click) keep opening and reading the threads you WILL find what you need to know.
I like this one:
https://www.ford-trucks.com/forums/6...l-removal.html
So far I haven't solved my dead cruise, I have jumpered out the recall harness /pressure switch and now I can engage the system, it just wont react at all......next step.........Amazon
for a new servo
Old 11-22-2014, 09:04 PM
Vince79vette's Avatar
Vince79vette
Vince79vette is offline
Is ur dash in ur car and does everything work? Reason i ask is i pulled my dash to put a tablet in place of the hu and all i have hooked up is the headlights switch and my cruise wont work ether but i work 100% perfect right before i took the dash out
Old 11-22-2014, 09:27 PM
Lance Helmert
Replacing the sensor on the master cylinder fixed our cruise control.
Quick Reply: cruise control not activating
