Broken dip stick in tube, how do I retrieve it?
The farm I work for has a 2003 F-250 with a 7.3 and I noticed today that I didn't have a dip stick on the end of the handle when I went to check the oil. From what I can tell the stick is about 1.5-2 inches down in the tube. I was hoping to get some ideas from you guys with 7.3's on how to do this if it has happened to you before. The tube is pretty tight, so our options are probably limited (tried needle nose plyers, no luck there).
Any help would be greatly appreciated, Thanks!
Adam
Adam
Crawl down under the truck. Just above where the dipstick goes into the pan, the dipstick has a joint there that can be separated. Remove the dipstick from the part that bolts into the side of the oil pan and you can get the dipstick out of the tube that way.
You'll need to remove a nut that holds the upper flange of the dipstick in place before you do this. The nut is on a bolt that holds the valve cover in place. Sometimes the bolt for the valve cover starts to spin instead of just the nut, so either grab some channel locks to hold the dipstick tube in place, or grab a back up wrench and hold the nut below the flange while loosening the nut holding the dipstick flange in place.
Edit: Or do what he said in a whole lot fewer words.
First try using a strong magnet along side the tube and slide the magnet up until you can get a pair of needle nose pliers on the end. Mine broke off at the T-handle and i was able to pry it out with a small screw driver if I remember correctly. I purchased a replacement from Ford for approx. $30 +/- and I do not like the way the new stick fits the tube - oh well.
