59 F350 Longbed
so ive slowly been tearing down the truck, so I can start my frame off restoration. im finding more and more rust, but I think it will all be fixable. it will just take a lot more custom fabrication since there is so little aftermarket sheet metal made for these awesome trucks. 1 question I do have is about the front brake drums. is there a place to back them off? or how do you get the drums off? any help would be great. ive enjoyed reading all your posts, so keep them coming.
CJ There is a slot window in the bottom of the brake baking plate, it may have a rubber or metal plug in the hole. Reaching through the hole with brake spanner or flat blade screw driver, you can loosen or tighten the star nut.
I would strongly suggest you pickup a shop manual for your truck they are well worth the 20-40 bucks you will find them on Eblay
Find the slot and stick the wand of some PB Blaster in there and blast away. Those star adjusters can be pretty stuck. If there isn't a bad ridge on the drum, they just might pull off after the normal wheel bearing removal. Take pictures as you go, not just for reassembly, but there are various old guys sitting around at night with nothing else to do but watch guys with more energy wrench on some cool old trucks. I know of one on an island who has been putting in way too many hours at work to have the energy for this winter's project after work. Thanks, Gary
Boy ain't that the truth! Sometimes I get tired just seeing what some of these guys have done.
shagnasty17
06-14-2014 02:48 PM
