E4OD od light blinking
#62
#63
Alright quick update i drove it and it shifted smoother than butter for ten miles on and off the gas i didnt drive it to hard but i did get on it a few times and no problems go watch a movie get in it drive it and then when i got off the freeway it started banging gears. I checked the fluid again and it is still to high. So im going to let it sit over night and let everything settle. Fire it up and drain some tomorrow and then do my rear diff fluid change. The speedo was bouncing still so im hoping the bouncing and over filled will all be resolved tomorrow and all will be right in the world.
#64
#65
#68
#70
I think i discovered why the speedo is bouncing. There are a couple groups of three teeth that were caked with crap in them but the gaps between them were open. I got them cleaned and looks like some of them are a little corroded so ill hope for the best until i get a new tone ring.
And after cleaning.
Also found out my pinion gear is walking around so a new bearing and seal is in order as well. That will be saved for another day.
And after cleaning.
#71
Quick update drained the rear diff cleaned some teeth on the tone ring refilled and test drove. I also drained some atf out of the trans. The speedo is still bouncing a little not like it was but that will not go away until I get pinion bearing and seal replaced. The ring carrier is also moving a bit as well. I think I have a restricted trans cooler so that will be on my list to do as well.
Any body ever flushed the trans cooler/radiator part and external cooler.
#73
#74
#75
The trans stopped banging so far after I drained some fluid out of it. I did the test on how much fluid comes out when you pull the rear line in 15 seconds and it wasnt even close to being 1/2 a quart. So either my trans cooler is restricting or my pump is bad. So im going to pull the top trans line off of the radiator and see what i come up with.
