Worst case scenario water pump change. Need advice.
I am in a real bad scenario with my 460 engine on my F250. The water pump is froze onto the motor so bad, I can not get it off. Ive tried beating on the old water pump with a hammer and obviously prying on it. When I pried on it with my screwdriver, I busted the thin water jacket behind where the water pump mounts. So my next question is now what? JB Weld?brazing? or selling the pickup for parts? Any advice is appreciated.
There's a couple of bolts tight up under the inlet port...
You can buy a new timing case for under $50
http://www.ebay.com/itm/like/170393931539?lpid=82
http://www.ebay.com/itm/Ford-429-460...-/281447280528
Be sure to check your counterweight for scoring.
You will ruin a brand new front main seal if you don't sleeve it.
fastphil
15
03-30-2018 01:09 PM
Spaznaut
05-08-2015 06:44 AM
1yamman350
02-06-2005 05:26 PM
