F250 7.3. No crank starter issues stumped!
2001 F250 7.3 diesel
No turn over - 1 click selenoid engages but no spin on starter.
Grandpa says heard a pop or short sound when tried to start first.
Replaced:
- ignition starter switch under steering column
- solenoid on fender well
- nuetral safety switch
- 2 new starters.
- 2 batteries
Verified :
- can hand turn motor not hydro locked.
- 12.5 v to solenoid on brown w red wire from nuetral safety to solenoid when key in start
- 11.6 v to starter on main battery cable
- 12.5 in new direct wired jumper from solenoid to starter
- solenoid click only in park and nuetral ( assume good nuetral safety switch)
Will not start by direct shorting solenoid
Will not start by direct shirting the starter
Starter will engage/spin out of truck but will engage no spin hooked to truck free and dropped
Replaced:
- 2 new starters.
- 2 batteries
Verified :
when you say "hooked to truck free and dropped "are you say hot wire hooked up but starter not mounted. I may be wrong but believe the starter uses the block as ground so if its hanging free you have no ground.
Realslowww
11-28-2016 06:11 AM
court1100f
18
04-09-2014 11:22 PM
ericconn
06-03-2013 10:33 AM
allisonmo2
03-12-2009 08:52 PM
