09 SC FX4 4wd
09 SC FX4 4wd
New Guy here with a few Questions and hope for some answers or help
4.6L 4x4 Fx4
1 - inspection problem that I have never had before
They said my EVAP was one
and O2 sensor and Exhaust O2 where flashing Not Ready
I did what they said drive 50 miles come back well this time it said Cat was one now IDK what to do replace them all.
2 - I have this clatter I refer as souding like a Powerstroke
When I had TB-injectors-plugs and Radiator flush 2wks ago at the dealer I asked them to listen to it prior to the service. They said its normal ford sound.. hmmmm Not agreeing to that.
3 - I have what sounds to me like my front end exploding threw my fendrrs and I cant seem to find the problem its if I hit a buump or even ond a rough road its loud banging sounds ... my shocks are fine
Sorry to keep on ranting
4.6L 4x4 Fx4
AzleTXGraves ... 4.6 ...
*8th VIN character ...
- W = 2V(alve)
- 8 = 3V(alve)
1 - inspection problem that I have never had before They said my EVAP was one and O2 sensor and Exhaust O2 where flashing Not Ready I did what they said drive 50 miles come back well this time it said Cat was one now IDK what to do replace them all.
2 - I have this clatter I refer as souding like a Powerstroke When I had TB-injectors-plugs and Radiator flush 2wks ago at the dealer I asked them to listen to it prior to the service. They said its normal ford sound.. hmmmm Not agreeing to that.
Where (general area) is the sound coming from? e.g. valve cover(s) | FEAD | A/C | bottom of engine | exhaust manifold | etc., etc., etc..
-click- the pic'
Goth 150
< This space intentionally -blank- >
3V
171000 miles
Today the code w no light came as UO100
Said ECM prob
Prior to that just EVAP anlong with O2 and O2exp or something like that
Also cat flashed code too
That one might be the reason for random truck shut off at a light as im slowing or taking off
2:
The sound come at any speed and accel and decel
I think lifters but like I said Dealer said it was normal but I dont think so
3:
I have checked all bushings ect cant find the main prob just lound and
Annoying
4: also would a high flo cat help any?
Thanks agin for being the one to only reply
3V
171000 miles
Said ECM prob
2:
3:
Annoying
AzleTXGraves ...Today the code w no light came as UO100
Said ECM prob
Said ECM prob
Lost communication with the engine control module (faulty ECM | shorted ECM harness | poor electrical connection).
You aren't by any chance using a hand-held tuner are you?
2: The sound come at any speed and accel and decel
3: I have checked all bushings ect cant find the main prob just lound and Annoying
No dis', however, from everything you've posted thus far, the recommendation would be to take the vehicle to a quality repair facility and have it THOROUGHLY inspected and diagnosed.
Thank you for your feed back and everything
And correcting me on the codes
I will have everything rescanned again
Yes sorry I was running the Bully Dog Gt on Premium for millage I drive alot working in the Oilfield and have the truck monthly maintained
All Dealer paper work also states its an 09 SuperCrew FX4 too
The Cat would be to replace my factory one seems tho its reading bad on OBDII scan but I did however pass today finally with only EVAP and Cat code the O2s cleared out
AzleTXGraves - Its also the 4 speed 4.6l
- 8th character of the VIN - "8" would indicate a 3V.
. - engine - 4.6L (2V|3V) was not available in the FX.
. - transmission - the 4spd (4R75) automatic was only coupled with the 4.6L 2V. *ALL others (4.6L 3V and 5.4L 3V) got the 6R80 (6spd).
So ... Either it's NOT a FX4 -or- someone (?) replaced the engine and transmission (which would also mean a ECM swap/change).
