Identifying tow package on 95 f150?
So, first post long time lurker. I think I have the towing package on my 95 F150 and reading other threads here I have figured out what to look for. So I see the blue wire here
oil cooler here
and small box next to large fuse box here
Kinda maybe?
then I have this connector back near the spare tire.
Am I on the right track, does this indicate I have the towing package and I can plug and play the teko brake controller I just purchased?
oil cooler here
Kinda maybe?
on
pic 1.
tow pack or not,ford ran the brake controller plug in the cab but the blue wire dead ends if it doesn't come with tow package at the firewall plug (along with many others dead ended there.)
pic 2.
sure its not an aftermarket trans cooler?
pic 3.
your showing a connector,nothing that looks like a pair of external relays.
(i dunno what that is.)
pic 4.
iv not heard of a truck with the tow pack coming without the rear tow plug already mounted.there are only 2 pins there anyway.not the 7 pin/wires the tow harness would have.
in this thread someplace,i install and show pretty decent details how to add the tow package seamlessly into the truck.i bought an f450 that didn't come with it (strange enough i know.im still in disbelieve myself).
1993 Ford F-Super Duty XLT - "Log Truck" (new to me truck-pic heavy)
pic 2.
pic 3.
pic 4.
Ya I am pretty sure it's the factory oil cooler, thanks for confirming Dixie. Any idea if it's plugged into the radiator. I have a new radiator I need to install but I am trying to figure the details on that too before I just take everything apart.
So it looks like your ford is a 96 which was more common to have the tow package on. Just wish I had something like the door sticker I could look at to see if it's there. Mine is a 95 but earlier 95 I think because it doesn't have MAF.
Thanks f250 for that write up gonna go over it. Ya the 2 pin connector is the only thing I can find in the back and while there is some info out there on figuring this out there aren't many photos.
IIRC the factory heavy towing package included a plug in for a brake controller under the dash near the right side of the steering column, a seven way plug wired into the rear harness (with a 4 pin adaptor to use a regular four pin flat trailer plug), handling package (HD front sway bar, rear anti-sway bar, HD shocks), a class 4 trailer hitch and an oil cooler for the transmission.
I believe you also got your choice of the bright swing-away mirrors OR low mount towing mirrors.
