Need advice on central fuse panel
Old 09-03-2014, 08:01 AM
miko6810's Avatar
miko6810
miko6810 is offline
My trucks been acting funny when it rains, I figure it's the gem module getting wet. Take it to my ford dealer and they say the central fuse panel is getting wet and they can't open it to see how bad and it's a 2000my only part that's discontinued from ford.
Anybody have an idea? Or have one for sale? Or know of a company the rebuilds them? My truck has been sitting for a week and I'm bummed! Help!!
Old 09-03-2014, 08:06 AM
David7.3's Avatar
David7.3
David7.3 is offline
Yea I have replaced quite a few of them, they burn up inside from moisture, I didn't realize they dont make them any more, let me look around.
Old 09-03-2014, 12:07 PM
Archion's Avatar
Archion
Archion is offline
do you have what the original Ford Part or Engineering # would be? I'm sure there are still plenty out there in the dealer/warehouse network, usually you have just a lazy parts guy.
Old 09-03-2014, 12:32 PM
miko6810's Avatar
miko6810
miko6810 is offline
You'd think a part like this would be stacked like cord wood in some dusty warehouse. But I've looked at other sites and this has been obsolete for almost 8-10 years... Really don't want a "maybe it works, maybe it don't" crapola from E-bay.. I'd like to find a place that can refurbish it.. Or clean it up as best I can and try to seal up my windshield.. Maybe craft up some type of water deflector and slam it back home and call it a day..
Old 09-03-2014, 01:11 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
YC3Z-14A068-BB
Not a dealer in the county has one.
Old 09-03-2014, 02:44 PM
Pele's Avatar
Pele
Pele is offline
Well this makes me nervous about my 2000. I haven't had the opportunity to get it out in really bad rain.
What's your trick do or not do in the rain?
Any ways to prevent this?
Will a SuperDuty GEM and or Fuse Box fit?
Old 09-03-2014, 02:47 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
maybe us that dont have a defective one can put it in tupperware somehow to protect
Old 09-03-2014, 04:46 PM
Archion's Avatar
Archion
Archion is offline
My best bet would be to call an LKQ and see if they have in used in their nationwide network. I guess I ought to start looking for a spare, mine quit powering the OBD-II port and the bottom lighter, same circuit.
Old 09-03-2014, 04:58 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Ok, let's not all be dicks and buy them up before Miko can get one at least. Can we not at least get him one first
Old 09-03-2014, 05:02 PM
Archion's Avatar
Archion
Archion is offline
Imma start a fusebox jacking ring, Pull you over, knock you over the head and gank your fusebox...
Old 09-03-2014, 05:41 PM
Apocalypse's Avatar
Apocalypse
Seems like there are better things to take on an X... just saying lol.
Old 09-03-2014, 06:04 PM
Archion's Avatar
Archion
Archion is offline
Parts made from unobtainium are always in demand
Old 09-03-2014, 06:58 PM
Avitech's Avatar
Avitech
Avitech is offline
If you drill out just the end of the bits circled in red, just to the threads, you should be able to open up the fuse box (they're kind of like rivets.) Then get a good can of electrical contact cleaner and a toothbrush and clean to your hearts desire! tough corrosion can be worked on with a piece of scotchbrite or similar.
Old 09-04-2014, 06:31 AM
Archion's Avatar
Archion
Archion is offline
Those look like threaded inserts that hold the harness in place.
Old 09-04-2014, 06:56 AM
Avitech's Avatar
Avitech
Avitech is offline
They are the hold down points for the harness, that's why you don't want to remove the threads just the shoulder before the threads start. They also hold the fuse box halves together using that shoulder
Quick Reply: Need advice on central fuse panel
