where is this clunk coming from?!? 2004 f350
I just bought a 2004 f350 4x4. There is a horrendous clunk coming from under the cab as soon as I steer and at certain rpm while driving straight. I have researched this topic for hours and everyone says sway bar links. Well heres what I have done so far and the truck still has the same terrible clunk. New sway bar links, new sway bar bushings on axle, new front drivers hub, new front passenger hub needle bearing, both front dust seals on axle, greased all ujoints and balljoints, tightened up some bolts for the dual steering stabilizer, and shook the heck out of all other ujoints and the cab mounts and they all seem good. Anyone have any ideas? This is driving me nuts!
Thanks guys,
thebluemule
Thanks guys,
thebluemule
How many miles on the truck? Have you checked the track bar? I would jack the front of the truck up and set it on jackstands under the frame on each side, and get the weight off of the front axle/wheels. Then you can shake and tug (within reason, of course- don't want to pull it off of the stands) without load on the components. My bet is it's the track bar bushing on one end or the other.
It's probably not driveline related, unless you drive with the hubs lock in all the time.
Thanks
Thebluemule
Well I greased the slip joint but didnt get to check the track bar yet. I have come to the conclusion that I must have been dealing with a few different clunks. The slip joint was bone dry. So I greased it and took it for a test drive. There was still an obvious clunking/grinding but now only when turning. So the slip joint was part of the
Problem but the worse sounding one is still there. Now as I am driving down the road (no matter what speed) and I turn the wheel to the left, the terrible clunking/ grinding noise pops right up. If I turn the wheel to the right or drive straight it stops. I am wondering if the passenger side hub itself is bad now, as after I took it off to install the needle bearing I have an abs light on. I still havs to set it on jack stands and check the track bar and etc as well. Any new thoughts? It does feel like its coming more from the passenger side.
Thanks!
Thanks!
I know you probably already checked this but when I drove my F350(same as yours) with the hubs locked but not in 4 wheel I always got this clunk when turning. The truck had manual locking hubs, when they where locked it did this but when they were in Free they didn't.
Good luck in finding what it is!
I forgot to mention that this is with the hubs locked or unlocked. Thats what made me think the whole hub assembly might be bad and not just the needle bearing I replaced. Maybe? I am going to check all exhaust hangers and inner fenders again tomorrow along with jacking it up again and shaking everything. And anyhing else that anyone suggests
Thanks for the reply!
Being leaf-sprung, it could also be worn spring eye bushings. I have an old 75 GMC (with 55,000+ original miles) that clunks like crazy. It needs all new bushings.
If I'm guessing, he indicated that he "lubed" his ball joints, not replaced them.
Jack each wheel off the ground and get a crowbar or wedge into the ball joint space. If you can lift and get space, chances are it's clunking as you turn.
Good luck.
Don't you just hate when this happens. Why can't people make the time to post the solution when they had enough time to ask the original question? Now 9 months later.
Good luck.
Good luck.
I do hate when we don't get a resolution, on mine it is speed related , even if I keep the steering wheel in the same spot as I am moving forward slowly it makes what sounds like a tire rubbing sound and even vibrates my mirrors. I checked tonight again and found a U-joint with some slop in it at the rear axle. My hanger bearing rubber is also very sloppy so I think I will go through the whole driveshaft with new joints and hanger bearing and see if that solves my issue...
I had searched for the problem for a while before I found it and had forgotten all about the post here. It was the down pipe hitting a bolt on the front springs on mine. I wasn't 100% sure that was it but I loosened the clamp on the downpipe, had a buddy hold it away from the bolt and I tightened it. Quiet now.
