I'll have to look at my X, but in that rear pic u think those are the stabilzer bolts that keep the barn doors from moving. I'm thinking it's just the rusty heads on the bolts! I have never seen an X rust there!
That rust that some of you are seeing is just the heads of the bolts for the barn door sockets. The entire back panel has a plastic covering. So even if it was rusted you would see it!
Yes it would've been nice if they said how many miles the X has on it!
It sure would be fun to bring it home for a few days though. I can't see it going offroad, wheel base is too long to even go over a curb it would get stuck high centered.
Plus there might be an echo echo and time delay from the very back. Time delay from very back.
If the standard. Excursion rear doors are the same units as the Crew Cab trucks of the same year, what are the middle and rear doors from on that 6 door creation?
Excursion doors are NOT the same as the crew cab pickups. They are longer and curved.
The doors you see in the middle ARE stock 99-2015 Crew Cab Super Duty rear doors.
Guys, you gotta remember its no longer then a stock Crew Cab Long Bed pickup...The Excursion is actually pretty short...the same length as a REG Cab Long bed super duty.
All EX rear seat doors are loonger than the same year SD truck's crew cab doors. On these 6 door stretched EXs they use the rear crew cab doors from the SD trucks in the middle position and the EX's rear doors for the rear set. The front doors are common between the EX and SD trucks. And Russ types faster than me.
I was eating a panini when looking at the picture and literally stoppped chewing when I saw it had only 45 miles.
First thought: "Yep, something is terribly wrong with that truck."
My 2001 Excursion had 50 miles on it almost exactly 13 years ago when it was purchased new.
Oh come on! I know that ain't gonna make you stop chewing brother!
This should read I swallowed the rest of my panini so I can read the rest of the ad.
