Adjustable Vacuum Advance - 300 Six?
Old 08-27-2014, 09:51 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
Well, the good news is that the vacuum canister on the distributor currently in my truck is, indeed, adjustable with an 1/8" allen wrench.
Perhaps the reason the numbers do not match up with the 1982 date, which I provided to Gary, is that when initially converting to Duraspark, the salvage yard, where I purchased the distributor, said the donor vehicle was a 1982 [maybe it was 1981 or 1983?].
  #32
Old 08-27-2014, 10:00 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Yes, as said just now in the PM, I forgot that the truck is an 86. But I'd bet that the extra dizzy you have is an 81 version as the number matches perfectly to the parts catalog. (Not that I'll fight to defend the parts catalog, but on Calibration Codes it probably had to be accurate.)
So, we have two adjustable vacuum advance units (cans ). That's good as we may find the one in use now won't give as much advance as the engine wants, so it is good to have options. IIRC we can cut the stop on those to allow more advance if needed.
  #33
Old 08-27-2014, 10:06 AM
1986F150six
I just love it when a plan comes together!
  #34
Old 08-27-2014, 10:57 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Crane advance units use a 3/32 long shank allen wrench.
If stock units are already adjustable there's no need to order a new one.
I'd still be interested to see if a Crane can will fit an I-6 distributor.
  #35
Old 08-27-2014, 11:02 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
We will check when David's here to see if my Crane unit will fit, just for reference and future use. I guess I need to start creating the to-do list in Evernote or I'll forget that bit. In fact, it would probably be a good idea to post it here so's y'all can help flesh it out and re-order it.
  #36
Old 09-01-2014, 09:08 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Look at the tags on this thread, it's an example of why I delete many of them:
https://www.ford-trucks.com/forums/1...how-to-11.html
  #37
Old 09-01-2014, 09:30 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I only see one: I6 distributor rotation. And we did discuss that. What am I missing?
  #38
Old 09-01-2014, 10:52 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
You are somehow missing this, I'm guessing you're not looking at the thread I pointed out?
<table class="tborder" width="100%" align="center" border="0" cellpadding="6" cellspacing="1"> <tbody><tr> <td class="thead"> Edit Tags
Tags </td> </tr> <tr> <td class="alt1 smallfont" id="tag_list_cell">1986, 460, conversion, duraspark, f150, flathead, ford, georgia, i6, ii, parts, picture, plugs, spark, upgrade, vacuum </td> </tr> </tbody></table>
  #39
Old 09-01-2014, 02:09 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Missed the link on this phone. Obviously those tags are mainly worthless.
  #40
Old 09-01-2014, 03:01 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is online now
Originally Posted by 1986F150six
What I did find interesting is that 2 canisters for the 4.9L and 1 for the 351 indicated that "Advance starts @ 5" Hg". If you recall in a recent thread where I was discussing that I had measured the vacuum of the sole carburetor vacuum port [using 1970 Carter YF] and it was 5" Hg @ idle, but never exceeded 10-11".
FWIW, I've just bought a new vac advance for my truck (V8) through Rockauto which also specified 'advance starts at 5" vacuum'.
I plugged a gauge onto it & applied vacuum; full advance was in by 9" Hg....+ or - depending on adjustment.
  #41
Old 09-01-2014, 05:04 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
So, when we map the curve on David's vacuum advance we shouldn't be surprised if it is all in by 10". And, we should map the vacuum at the port on the carb to manifold vacuum.
But, did yours actually start at 5" Ken?
  #42
Old 09-02-2014, 04:13 AM
Ken Blythen
I don't remember, Gary.....I'll look again tomorrow.
At the time, I was just checking that it was fully advancing below idle vacuum.
  #43
Old 09-02-2014, 08:14 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Not to worry, Ken. We will map his and know for sure.
  #44
Old 09-02-2014, 08:19 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The arm is not truly tangential.
I'd imagine the action is not linear either.
  #45
Old 09-02-2014, 08:45 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
My first thought was to map the actual travel of the arm vs vacuum, but then I realized that it doesn't matter as it might not be linear. And your observation explains why. So we will just use my Mityvac and map it every 1" of vacuum, but will tee the vacuum gauge on my diagnostic machine in as it is much larger and reading it will be a lot easier.
brian.b
09-23-2016 08:06 PM
sausrigging
05-28-2006 12:20 PM
little_mule
02-23-2006 06:55 AM
Quick Reply: Adjustable Vacuum Advance - 300 Six?
