Mishimoto 200° vs. Ford 192° thermostat
#1006
Put my Mishimoto back in, the new OEM thermostat I installed started to open at lower and lower temps, I decided to give the Mishimoto a try again. It hangs right at 200 degrees, more consistent than the OEM. I have a long run pulling my small trailer in a couple of weeks so that will give it a good test in warm weather.
#1007
#1010
Go to "User CP" select "Edit Options" scroll down a bit and you'll see a setting for # of messages per page. Set it to 40. This thread will only be 26 pages then, and you won't be eligible for a free vehicle any more.
#1011
#1012
with the 100 degree weather and high humidity my Ects are around 202-204 and EOT 209-211. This is unloaded around town and highway with ac on. I plan on doing a test run pulling my jeep to see what the temps do. I am thinking I will be putting a stock thermostat back in for the summer.
#1014
Towed a 1500lb load a couple weeks ago, up and down some good grades, numbers didn't really change. I know that most tow 4-8k loads and this might not really count as a good observation.
It would hold off the cooling a little longer, may make the system work a little harder to cool it down. But for me, not towing that often, the increased mileage of daily driving, mine is staying in.
I'd be curios to hear what you find/observe.
#1015
#1016
Rogers ave can play hell with temps! I still have the strange issue of my ect dropping to 190-194 while driving. Pretty sure it is a sensor or wire issue. havent noticed anything else being strange.
#1017
Maybe we should swap SGII's for a bit and see if that persists. Or you can just get mine while I'm not driving after hip surgery and see WTF.
#1018
#1020
