Mishimoto 200° vs. Ford 192° thermostat
#736
#737
I own a 6.0 and I have been driving a 6.4 at work since 2008. The 6.4 I drive has never had a problem keeping coolant temp up around 200*.(with no load) I put Torque Pro on it this morning, and after it was completey warmed up, I took the screenshot below. (some gauges read nothing due to the 6.4 doesn't read all of my 6.0 gauges I have listed.) The 6.4 uses 2 thermostats.
For what it's worth, I will never own a 6.4, even though their thermostats seem to work as designed.
Thanks!
#738
Hi All,
Thought I would share my findings from using my 2005 6.0 Ex with the 200 thermostat. I have had a Scangauge hooked up and have found that it holds the engine very well at 198-200 even with outside temps below 0 farenheit some days. I was very surprised how long the motor took to get up to 200. I found it climbed quickly to 175-180 and then slowed down but still got to the 200. All this is while driving at 45-50 mph and with a winter blanket on the front grille. Overall I would recommend this thermostat. Time will tell how this works in the heat of summer with the AC on full blast.
Rob
Rob
#739
#741
Temps 204-206 with the occasional run to 100. I was following traffic and a sweet looking black new 5.0 Mustang GT.
#742
I left the house at 2:52 and pulled into Prothro Junction at 5:00. I followed the M-F college kids home and they were in a hurry so I just cruised... Took my time and was back home by 9 pm.
2006 F350 4X4
#743
Hi All,
Rob
Rob
Fantastic! Enjoy.
#744
#745
Sure that's just the +- on the calibration of the sensor--i could be wrong though.
#746
#747
#748
OK so I went thru this thread somewhat, but didn't have time to read all 700 posts...
Does anyone know what washed out with the t-stat fitting the older housings?
I recently bought an 04, and I'm doing the work up on it now, was going to replace t-stat with this new one but am reluctant to do so now due to it not fitting (in some) of the housings.
Did Mishimoto fix this issue? Any suggestions?
Thx
Thx
#749
Thx
Thx
2006 F350 4X4
