Mishimoto 200° vs. Ford 192° thermostat
#1201
#1202
Originally Posted by 03-6L-X
I have gone through two Mishimoto T-stats in a year. Work fine for a while and then break. A real pain having to take it out, take a picture and wait for them to send you a new one.
#1203
Have had mine in for a year and a half. For the first year it was steady 200, only varying when climbing mountains...and that was with bad headgaskets. The last few months, however, it has varied between 196 and 200 now that the headgaskets are fixed. Starting to wonder if it's going bad.
Even if it does go bad a year is 4 times as long as the OEM thermostats I'd been replacing were lasting.
#1204
#1205
#1206
Got it in! Once I actually had it in my hand I felt stupid for even asking. It was obvious lol. The plunger held the thing at least an 1/8" up, almost broke my fingers trying to compress that spring so I just boiled it alone and then compressed the plunger and it popped right in. Thanks all for your help. Esp you tfunk, couldn't have done it without your explicit instructions
I'm officially joining the ELC and mishi crowd, I feel so popular! Cant wait to see how it runs and what the temps will be!
Is yours still functioning as intended? It almost seems to me the pilot hole should be deeper.
#1207
on
If the pilot hole was deeper it will open later at a higher temp than the 200*.
The reason I say that is when I had first purchased mine I didn't boil it and had the same issue everyone else had so i cut the rod about 3/16" and installed it. On the way home I was seeing 209-211* and the fan was screaming so I knew something was wrong. Came home and read a few more pages of this thread and realized my mistake so ordered the correct housing found the rod I cut off and welded it back on and while hot installed in the housing but still had temps of 204-206 so I found my old thermostat and cut a small piece of of it and put it in the housing hole as a spacer and saw temps of 198-201.
Long story short the deeper hole the higher the temp.
I have since removed the 200* and put in the factory thermo for the summer and will put it back in during the winter months.
#1208
Now I got all kinds of ideas to experiment with a stock one.
#1210
Well, 2 boil cycles and it's still not tight on the seat like the Moto-rad that I put in there too. The Motor-rad started opening @ 195 and fully opened at 210 while the Mishimoto only opened less than half. Kind of expected that of course. I had a good side by side pic but for whatever reason it "blackscreened" on me and didnot come out.
I guess I will drop it in the truck and see what it does.
#1215
