Tranny question - what do part houses call mine
The Ford VIN lookup refers to my transmission as a Ford 3-speed light duty trans.
Well I am wanting to acquire a transmission shaft seal for mine and the closest I have come to matching up is a borg-warner t85 or t89.
It's the three on the tree with the highest speed rear end - the lightest combination ford put out according to what I can gather.
My new motto - fixing leaks one step at a time.
Not even going to touch the pinion portion of my leak yet.
D9BZ-7052-A (replaced 21C-7052 - A2TZ-7052-A - C4TZ-7052-A) .. Extension Housing (Output Shaft) Seal / 2.378" O.D. x 1 1/2" I.D. x 1/2" thick.
1942/47 Commercial (1/2 ton) 3 speed / 1948/52 F1/F2 3 speed (except Warner T-87 H/D) / 1953/62 Warner T-86 3 speed & 3 speed with O/D / 1963/64 Warner T-86 3 speed O/D / 1963/87 Ford type 3.03 3 speed.
1965/71 Warner T-85 O/D & Warner T-89 are not the same.
1963/83 F100: Type 3.03 was the only 3 speed manual available, excepting 1963/64 F100's with Warner T-86 O/D & 1965/71 F100's with Warner T-85N O/D.
These two 3 speed O/D's were optional.
Note: This 3.03 and etc extension housing seal was also used with the New Process 435 4 speed. Give the chain auto parts store parts-cluck this New Process part number: 96733
rsh1966
02-08-2017 07:35 PM
luv2ski
03-27-2013 05:22 AM
995.4SD
07-19-2011 09:03 AM
bcam69
01-20-2008 10:25 PM
60FordF100
11-23-2007 12:08 PM
