Well, exhaust manifold repair just turned into a full blown motor swap, need help
Have been repairing some things on the truck,2002 f250, 5.4, including the pass. exhaust manifold..few studs were snapped off in the head and needed to be drilled and ez'd out. was on the last stud, and the drill bit drilled through to the head.dont even know how because i never felt the drillbit punch through the stud so i knew to stop...long story short, my heads ruined. and since ive been having so many problems with this motor, at this point im just gonna swap it out. so my first questions of many is, how do i start? is there a sticky or tech write up of any kind? where can i find a motor? will an 04 and up motor be better than the one in there now? i have endless more questions soon to come, just overwhelmed at the moment, so any tips are appreciated and certainly welcome
If you just hit the water jacket you can tap the whole way then use a set screw with thread sealant on it to seal the jacket. Then put the exhaust manifold stud in.
In 05' Ford went to the 3V engines and changed quite a few things so a swap would be much more complex with a 3V. Best to go with an 04' engine IMO because you will be ensured to have the updated heads.(added thread length in spark plug holes)
Whoa there, I would try this first! Don't be so quick to tear out the whole engine.
Head change
I did the same thing on my 2000 Excursion. Knew I did it because coolant starting dribbling out. Even used the left hand drill bits so I didn't need an easy out. Was able to find a low mileage head on ebay and swapped it out, complete with new chains and gears in one day. The 5.4 is really easy to time, teardown and rebuild. Best gas truck engine I've ever worked on.
yea it must have juuust touched into the jacket its just a small drip but its weird...the coolant came out it seemed before the bit punched through the stud...we started small then increased the bit size, so maybe the smaller bit did go through the stud and we didn't feel it until we went up in bit size?
I was wondering if we could do that, im in the heating trade and we have all types of good thread sealants...like stuff that once its on it will literally never ever come out lol..would you be able to clarify this process a little? what could I use for a set screw? maybe cut one of the old studs down and cut a notch in it then send it in with a flat head screwdriver? or can I just put dope on the stud itself and use that for a seal?
They are blind holes.
That sucks man! When you drill you really should mark the bit with how far you want to go (Use an old stud as reference). OR get one of these
Hindsight is always 20-20 I guess! Interested to see what you do.
General Tools & Instruments S838 6 Piece 3/16-Inch to 1/2-Inch Drill Stop Assortment - Power Drill Accessories - Amazon.com
