Rear Frame Repaint and Suspension Rebuild
My goal was really just to extend the life of the frame so that it lasts another 5-8 years. Since the factory paint was gone it was rusting away at an alarming speed. I figured at the rate it was going I'd have holes in the frame in 1-2 years.
Alex, remind me, and every spring after the road salt has punished it for 4 months I'll take a picture of it.
Is that the dually teal truck?! I never realized it was a dump bed. Thats freakin' awesome!
I wish I could sandblast everything. Mom would kill me if I did that in the driveway or yard...not sure if they'd care at my apartment complex.
Same with what Nate said. I'd love it if somebody would do the same prep on both halves of a frame, but coat it with different products. Then take pictures a few years down the road. lol
No, that is a F550 i restored a couple of years ago.
As for 2 products on each half of the frame, that would be pointless. the drivers side always gets it worse
The f550 before , during and after
Also, why does the driver side get it worse? Is there something there that catches more than the passenger side?
man, those frames look good - i'm going to be checking back on this thread as i attempt to make mine look that good!
do you feel the paint penetrated into the crevices where the cross-members are riveted the frame rails? i'd think that'd be the first place rust would start again? or maybe the factory paint was still OK there?
The worst rust decay I found was where my DMI bumper hitch bolted to the frame and the rear-most cross member above the front fuel tank.
Brad is right about the driver side being worse, much worse. I don't know why, but its definitely true.
No I don't think it penetrated between the parts that are riveted to the frame. The factory was gone but the decay in these areas wasn't even close to the worst areas. I'll be sure to get some pictures in those spots too for comparison later. If I were doing a full restoration, not just delaying the inevitable, I would have probably replaced the cross members and painted them before assembly.
The PO had already replaced my rear mounts with some heavy duty bolt on ones. They have a nice drain hole and everything.
Awesome thanks for the info! Makes sense to me.
