Parking Light on 1AAuto '08 lights.
Old 08-16-2014, 09:15 AM
Technologiq's Avatar
Technologiq
Technologiq is offline
Purchased a set of the lights with the chrome and ptm caps. They installed great without the need for the adapters. Whole process took about 5 minutes per mirror. They work great for heat and the turn signals but I've noticed I never see the lower bulb go on which apparently it should when I have my headlights or parking lights on.
Anyone point me in the right direction to get this fixed? Thanks!
Old 08-16-2014, 09:27 AM
william_04_x's Avatar
william_04_x
william_04_x is offline
Did you check out the write up in the tech folder, Jeremy? You'll need to add the running light circuit to the new mirrors. It can be tapped from the harness as shown, or the HL switch itself.
Old 08-16-2014, 10:10 AM
johntpr's Avatar
johntpr
johntpr is offline
Old 08-16-2014, 07:39 PM
Technologiq
Thanks guys. I knew the install went a little too easy
Old 08-16-2014, 07:50 PM
william_04_x
The rest is cake too. Fishing through the dash, and door boots isn't hard. Tap the brown wire on the HL switch after verifying it's correct with a test light. My memory is a bit fuzzy. I did this swap with OEM mirrors on my buddies truck. That was back in January, 2008. He wanted them for Feb dyno day. More horshpower.
Name:  2-2-2008 DynoDay 017.jpg
Sent from my Moto X using IB AutoGroup
mdbbrown
12-28-2012 01:26 PM
David85
10-25-2009 10:46 AM
wagntwister
1999 to 2016 Super Duty
04-15-2008 01:32 PM
hats2wt
2004 - 2008 F150
02-27-2004 06:10 PM
Karic
Electrical Systems/Wiring
01-19-2003 08:19 PM
Quick Reply: Parking Light on 1AAuto '08 lights.
