Help, What's causing this steering issue?
https://www.youtube.com/watch?v=ptz3...ature=youtu.be
Any insight? I'm leaning towards steering box, power steering pump.
Hands off the wheel, sorry about the poor video, (also vertical...) , but I wanted to get something without killing anyone.
7.3L 2003 180K
7.3L 2003 180K
on
I`de say either a bad tire (shifted belt) or a partially seized up axle U-joint. I`de lean more towards a U-joint since you say it`s intermittent. I did one on a customers truck a month ago. It came in for a shimmy that I couldn`t find. I test drove it for 10 miles and it didn`t show up. I did some other maintenance that it came in for then test drove it again, the shimmy was there. turns out it was a seized up U-joint. even with the hubs unlocked the axle will still partially spin and every once in a while it would stop in the seized up spot.
Here is what I would do. lock the hubs and turn the steering wheel fully left or right, jack up that wheel and spin the wheel. do one side and then the other, one of them is bound to be sticking.
Good luck!
Good luck!
Awesome, I knew this was a good place to post this, I do think that cranking the wheel may make it act up, I have to test it officially, I had some errands I had to run and didn't want to try and aggravate the situation. I'm going to change the fluid this weekend and get it up on a jack and poke around. I did get a chance to talk to my mechanic and he did mention it sounded like u joints. Thanks you all for the valuable insight, I just got off midnight shifts this morning, I'll get some time tomorrow to look into it. I will follow up with the fix when found.
I thought mine was U-Joints so I bought a set and pulled the bearing (they were tight with no wheel play) but when I pulled the axles the U-joints moved free with no play then I saw the Needle bearing in the back of the hub was shot.
It was cheek to buy new needle bearings and easy to change change them in the bearing
