63/64 cab corner trim molding
I've got a 63 f100 "wrong bed" short bed with the 63/64 aluminum trim with the red strip in the middle. Right now I've got two different sized pieces of trim on each side of the cab corners. Can anyone tell me the correct size? I'm assuming it's the longer one since the shorter piece was held in with sheet metal screws . And possibly a lead on where I could find the correct piece?
Thanks,
Seth
Thanks,
Seth
I've got a 63 F100 "wrong bed" short bed with the 63/64 aluminum trim with the red stripe in the middle.
I'm assuming it's the longer one since the shorter piece was held in with sheet metal screws.
Sheet metal screws were used because a previous owner could not find the correct moulding clips.
Call one of the following sources and have them measure the length of the right moulding.
C3TZ-81423A16-A .. Right Cab Corner Moulding / Obsolete
NOS PARTS LTD in Waxahachie TX has ONE = 972-937-2201.
KAMA OBSOLETE PARTS in East Bethel MN has ONE = 763-434-0123.
C3TZ-81423A17-A .. Left Cab Corner Moulding / Obsolete
1963/64 F100/250 with "wrong" beds. No Ford dealer or obsolete parts vendor has the left side.
C4TZ-81423A16-A Right & C4TZ-81423A17-A Left .. Cab Corner Mouldings / Obsolete
1964 F100/250 without "wrong" beds. No Ford dealer or obsolete parts vendor has either side.
C3AZ-6229120-A .. Cab Corner Moulding Clip-2 required per side / Obsolete
Same 1963/64.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
Thanks a million Bill. Looks like the longer one is definitely correct for the passenger side. Can't figure out why the drivers side one would be shorter.
If you get the chance, would you mind looking up to see if anyone has the cowl moulding piece too? It's about a foot long and in-between the hood and the door.
I really appreciate your time,
Seth
Seth
78F-250Lariat
07-13-2017 08:46 PM
Spencer Blackmore
01-01-2017 10:56 AM
nonoodlez
17
12-21-2013 01:52 PM
Triumph
11-11-2012 01:55 PM
