89 Terrry Resort Landing Gear Issue
I haven't seen any gears that are not pinned. The pin has to be driven out with a punch. I have pretty much stopped rebuilding legs when you have to go this far given the time involved, although I have done it in the past. If you buy gears, you will find they come in a set with pins and brass bushing normally.
I do not agree with you regarding replacing both legs at once. It is possible one is damaged and the remaining leg may last for years more. Often someone will decide to level side-to-side by raising way up on one leg or the other first and while you can do that in an emergency, I see some folks do it routinely and finally they destroy the leg.
My thoughts,
Steve
My thoughts,
Steve
My previous 5th wheel was a '94 Prowler.... same landing gear as the Terry ( all Fleetwoods). In it's last few years I had it it was always landing gear problems. Replaced the gears 3 times and when it failed again I started using cylinder jacks. Got tired of that real quick and traded it for my 2007 Arctic Fox.
My thoughts,
Steve
My thoughts,
Steve
I appreciate your professional advice, Steve. Thank You.
Just an Update
Stopped by local RV Recycle shop about a week ago. I brought the lead landing gear leg assembly for comparison. They had many different landing gear legs, so I chose one that was somewhat simillar in body style. The outer dimensions of the inner leg was exactly the same as the one I brought, so I purchased it.
It is a few inches shorter than the original one, but, I think that it will extend far enough to make contact to the ground when disconnecting 5er from truck.
I installed the inner leg to the lead leg and the worm gear engaged the nut. There didn't seem to be any slop so I think it is going to work out. I ran the inner leg all the way up the worm gear. At the top, the worm gear just spun with no resistance. I only ran it a couple of turns and then lowered the inner leg. I made a mark on the outside of the inner leg with a sharpie about 4-5" from the bottom so that when I stow the legs up, I will stop way before I can bottom out the inner leg on the worm gear.
Before I reinstall the landing gear to the 5er, I'm going to remove the rust and repaint.
F4WineGuy
01-09-2012 06:58 AM
