Help figuring out loss of brake pressure?
Old 08-08-2014, 09:47 AM
NBraun's Avatar
NBraun
NBraun is offline
4wd Low
I have a 69 f100, with drums all around. When i got it, it had sat for a couple years, and i replaced both rear wheel cylinders, and put all new pads and hardware in the rear, but didn't on the front. After that the brakes worked fine for a while. Eventually i had to start pumping the brake once to build up pressure. Now i have to pump a couple times to build up pressure, then i will be able to brake fine, but as soon as i let up on the peddle for a couple of seconds i lose all brake pressure and have to start over. Any thoughts on what this could be? I can't seem to find any leaks in the line, or in the front brakes. Anyways, thanks in advance!
Old 08-08-2014, 10:09 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Sure. Master cylinder has an internal failure.
Old 08-08-2014, 10:14 AM
NBraun's Avatar
NBraun
NBraun is offline
4wd Low
Alrighty, thanks. Thought it might've been that but didnt really think It through.
Sixtiesmusclecarguy
13
06-25-2017 02:46 PM
blackhawk21
1978 - 1996 Big Bronco
09-29-2013 09:08 PM
79f100six
05-07-2007 02:31 PM
cwgoff
1997 - 2003 F150
11-18-2005 12:27 PM
Quick Reply: Help figuring out loss of brake pressure?
