Gaskets for Sterling 10.5. & Dana 50
Old 07-25-2014, 04:42 PM
miko6810's Avatar
miko6810
miko6810 is offline
I ordered one of those aluminum diff covers and being of a time when "you used a gasket" I did some looking around on the interwebs and found Quad4x4 that sells gasket's for our Excursions.
QU40367 DANA 60/70 DIFF GASKET $10.09
QU40400 REAR DIFF GASKET $14.05
https://www.quad4x4.com
I'll probably use a small amount of RTV to set it in place, but I thought I would share the info..
Old 07-25-2014, 04:49 PM
Romanova's Avatar
Romanova
Romanova is offline
Did you get the appropriate hardware for the rear diff cover?
Honestly, I think most people just use RTV and don't have any problems. I just did mine this past weekend and used RTV... no issues.
Old 07-25-2014, 04:51 PM
miko6810's Avatar
miko6810
miko6810 is offline
I did order the longer bolts, ( not from ford ) because some bean counter at ford has issues! $8 a bolt? Yeaa okay...
Old 07-25-2014, 04:56 PM
Romanova's Avatar
Romanova
Romanova is offline
Make sure you get the washers too. If you didn't, PM me... still have some left over... minimum order of 50 when I got them lol
Old 07-26-2014, 05:37 AM
leftfinsright's Avatar
leftfinsright
leftfinsright is offline
I would skip the pre-made felt gasket entirely. I have changed the diff fluid in my Ex twice and used Permatex's gear oil RTV both times. They make an RTV specific for the differential (Permatex part 81182). A 3 oz. tube is about $9. I have had good luck with it; no leaks.
Gasket Makers : Permatex® Gear Oil RTV Gasket Maker
I also used the Royal Purple 75-140W syn for rear fluid. Its a little pricey but it has the friction modifier already mixed. Good luck.
Old 07-26-2014, 06:18 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
Reusable gaskets.
I bought the Lube Locker reusable gaskets for my axles when I bought the new housings with 4.88 gears and added the '08 SD aluminum cover.
They cost more than a tube of RTV but they can be used over and over so maybe in the end it's a push on the cost. No leaks so far with lots of heavy towing. LubeLocker - LubeLocker Ford/Sterling 10.25"/10.5" and for the Dana 50 up front LubeLocker - LubeLocker Dana 60
Old 07-26-2014, 10:53 AM
miko6810's Avatar
miko6810
miko6810 is offline
Well, I just cancelled my order with quad and got a set of these lube lockers!
Thanks!
Old 07-26-2014, 12:57 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
Good luck with them!
Take some pictures, I forgot to when I installed mine.
Old 07-26-2014, 07:35 PM
miko6810's Avatar
miko6810
miko6810 is offline
I'd like to replace the bolts on the front cover, can anybody tell me what size they are?
Old 01-15-2015, 08:29 PM
2000EX4X4LTD's Avatar
2000EX4X4LTD
2000EX4X4LTD is offline
I'd also like to know what size bolts to get for a 2000 Excursion v10 4x4.
Old 01-15-2015, 09:16 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
For the front Dana 50 with a stock steel cover they should be 3/8-16 x 3/4" and for the rear Sterling 10.5 with a stock steel cover 5/16-18 x 1" and if using the '08 finned aluminum cover discussed above the bolts need to be 5/16-18 x 1 1/4" (with matching washers). I used allen head stainless cap screws and washers on my alum rear cover to keep it looking snazzy.
Old 01-15-2015, 09:33 PM
2000EX4X4LTD
Thanks - that's a big help. I'm looking into these front and rear covers from cfrperformance:
1986-UP FORD STERLING (F-250-F-350-EXCURSION) CHROME STEEL REAR DIFFERENTIAL COVER - 12 BOLT W/ 10.5" RING GEAR
Do you know if the standard bolt sizes you mentioned would suffice?
Old 01-15-2015, 09:37 PM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
With them being the stock style (with chrome) steel covers the bolt sizes given above should work fine, use the shorter ones for the rear as the alum covers are a little thicker.
swmpbgy1
06-08-2017 01:25 PM
ericconn
09-19-2013 08:46 PM
savagehenry
08-22-2012 07:47 PM
DrCharles
02-26-2012 11:21 AM
btacarlton
08-13-2009 12:45 AM
Quick Reply: Gaskets for Sterling 10.5. & Dana 50
