Mystery Machine
I am going to buy a diagnostic tool and work on solving this issue with the help of you guys. What piece of equipment should I be looking for to give drivetime data to tell me where to look when I am losing power?
I see a 60694 on their website for $120. Would that capture live data and freeze a malfunction while driving?
Do you have a smart phone or something you can take pictures with and post them to the forum? Lots of numbers that need to correctly conveyed to those helping you remotely from the forum. READ the instructions that come with the tool. Especially the parts on recording live data pids and uploading them to your pc. Again read the book and then we can start collecting information and analyzing what you've collected.
I do. And I refuse to let this beat me. I am too deeply invested. I will make sure to upload and share all the info so that you guys can point me in the right direction. Thank you so much for your prompt responses!
Here is a couple of items / questions:
1. Is the check engine light on right now?
2. Engine power is ok at light throttle input but lacks power during heavy throttle?
3. What parts have been replaced so far?
4. Did you keep the old parts?
5. When you get the tool in hand let us know.
See if you can find the 20% off coupon on Facebook. Save a little on the tool.
2. Yes
3. Ok. Here goes. First off I have a 2001 E250 with a 5.4l engine and automatic transmission with 215000 mile.
In December I had a misfire on a couple of cylinders and I ended up burning up the cats. Misfire was corrected with new cop's and plugs. New cats (all 3). Shortly thereafter got the lean on bank one and 2 code. Shop said low fuel pressure so fuel pump and fuel filter replaced. No change. New shop found intake gasket leak that was causing vacuum and coolant to leak on cop's. Intake gasket replaced along with dpfe, maf sensor, throttle body, tps, air filter, egr valve, and all vacuum hoses. I have driven over 1500 miles since and have no check engine light and the mechanic said there are no stored codes.
Ok. To my problem. If I and just driving through the neighborhood I have no problems but if I try to climb a hill it struggles. I go from 70 mph to about 45 on a hill. The mechanic said the transmission is slipping. I took it to the transmission shop and they said there nothing wrong with it and that it is engine related.
4. I have a few of the old parts like the coils packs, maf sensor, iac valve.
I will keep you posted. All input is greatly appreciated.
#28
1. No cel
2. Yes
2. Yes
#30
Fixing the leak...I wouldn't know where to start. Did he not tighten everything? Did he over tighten and break something? I wouldn't know where to start. Of course I am willing to try with proper instructions. And by the way, I got a new set of coil packs and motorcraft plugs I want to put in but of course not until the leak is fixed.
Should I try or just let the shop figure it out?
captcaseyb
35
06-25-2016 11:57 AM
DrFord
03-28-2008 01:15 PM
