1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front wheel bearing replacement
Old 07-23-2014, 11:58 AM
bowler300623's Avatar
bowler300623
bowler300623 is offline
I am having trouble pulling the front wheel bearing off on my '03 F250 2WD V10. The outer bearing is destroyed. The seal and shell that holds the rollers in place is destroyed. 3 or 4 of the rollers are missing, and the inner collar is froze to the spindle. What is the best way to break the inner collar loose from the the spindle?
Old 07-23-2014, 12:52 PM
MC5C's Avatar
MC5C
MC5C is offline
If you can get at the inner collar you can apply a touch of heat to one spot, it will expand the ring and should let it slide off without harming the spindle. Or take a dull chisel and hammer on it, that will also expand the ring.
Brian
Old 07-26-2014, 01:39 PM
bowler300623
With some heat, a large heavy duty wheel puller attached to the rotor and some love taps from a 4lb sledge to a block of wood on the backside, I was able to remove it.
waylen89
07-30-2016 05:42 AM
NewEnglander
1978 - 1996 Big Bronco
01-24-2014 08:48 PM
2002f2507.3LPS
09-17-2007 03:18 PM
Dj300ford
02-17-2006 11:08 PM
jacque_strap
01-08-2005 12:25 PM
Quick Reply: Front wheel bearing replacement
