Sponsored by: Halo Lifts
2.7L EcoBoost 375HP and 375 lb/ft
Old 08-13-2014, 03:23 AM
Frdtrkrul's Avatar
Frdtrkrul
Frdtrkrul is offline
If Ford made the 5.0L EcoBoost, it'd be one bad powerhouse. My guess it'd be almost 650ft/lbs of torque. Though if it was offered in the SD line as well as the F150..wonder how that would affect diesel sales? I mean they just spent a lot more in the R&D for a larger turbo and exhaust brake. Plus with it being a gas burner instead of an oil burner, fuel costs will be down and maintenance costs will be much less...especially when one doesn't need 4 gallons of oil every 7500+ miles.
I have had the chance to test drive the 5.0L and the 3.5L EB at work for alignment checks and first impression they beat the crap out of the 2 valve 5.4L. So all I have to say is...SHUT UP AND TAKE MY MONEY! I want a 5.0L EB right now!
  #32
Old 08-13-2014, 05:19 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,222 Likes on 804 Posts
Originally Posted by tvsjr
I keep saying Ford needs to EcoBoost the 5.0 and make it an SVT motor. I'd buy one in a heartbeat. Assuming even 120lb-ft/L, that's 600lb-ft... sweet...
The latest edition of truck trend alludes to a bosted 5.0L code named VIPER, IIRC that will appear in the next gen Raptor trucks to replace the 6.2L.
  #33
Old 08-13-2014, 10:06 AM
RacinNdrummin's Avatar
RacinNdrummin
RacinNdrummin is offline
Originally Posted by IJAZ FAHTED
You guys that already own the 3.5 Eco-Boost Ford lied to you both about the HP-Torque, and MPG so NOW you trust them with the numbers on the new 2.7 Eco-Boost?
You have absolutely no clue what you are talking about.
  #34
Old 08-13-2014, 10:15 AM
Frdtrkrul's Avatar
Frdtrkrul
He's a Chevy bailout lover, could you expect anything less?
  #35
Old 08-13-2014, 10:26 AM
RacinNdrummin
My EB tows my 8000lbs excellent, gets 10mpg (right about what my IDI got under the same conditions), Empty I average 18mpgs in mixed driving. Freeway I usually average 21-22mpg at around 65mph. Biggest complaint I have is the soft suspension with the trailer on, its getting bags soon.
Im as happy as I thought I would be, if you expect any more out of a half-ton with a 3.5L engine and Auto in a 6K pound truck, your just an idiot who needs something to complain about.
  #36
Old 08-19-2014, 07:13 AM
tvsjr's Avatar
tvsjr
tvsjr is offline
I hope they offer it in non-Raptor varieties too (obviously, it would be top-range).
  #37
Old 08-19-2014, 01:40 PM
1saxman's Avatar
1saxman
1saxman is offline
Just imagine the 2.7 EB in a standard cab and 6.5' bed with no trailer! That's what I'm thinking about - it would have to be a blast to drive and would do everything my 2007 does, like taking a load of cuttings to the landfill. Who needs a Raptor?
  #38
Old 08-28-2014, 07:20 AM
MotorCityAutomation's Avatar
MotorCityAutomation
MotorCityAutomation is offline
This engine will also feature ferrous-iron plasma spray coating for the cylinder bores, no cast iron jugs that are on the current 5.0L. Similar process for the 5.4L Cobra engines. Here's an article on the process Ford launches plasma-sprayed cylinder bores on 2011 Shelby V8 - SAE International
  #39
Old 09-06-2014, 07:40 PM
johndeerefarmer's Avatar
johndeerefarmer
johndeerefarmer is offline
Originally Posted by Dr. Dirt
I hope so too. people also forget about the price of diesel and the price of an oil change, fuel filters, and DEF compared to a good ol' gasoline engine service.
If you tow heavy or in hot conditions you have to run premium in the ecoboost anyway (and most people in the know recommend premium in the ecboost ALL of the time anyway); therefore the price of diesel is not any higher than premium pump gas. DEF is usually only needed about the time you change oil and a jug doesn't cost much. I also don't expect a small displacement diesel to take much more oil than a gasser.
Most every one that has towed with an ecoboost will agree that there is nothing "economical" about the ecoboost when it comes to towing fuel efficiency. It get's about the same as a big block NA V8.
If my F350 (which weighs several thousand lbs more and is way taller) can beat my old '13 ecoboost both unloaded and loaded mpg by 15-25% imagine what a smaller displacement diesel in the lighter F150 would do?
The only downfall to the diesel will be the upcharge over the price of the ecoboost. If they make it too expensive it will take a long time to pay for itself.
  #40
Old 09-11-2014, 07:33 PM
jntibs's Avatar
jntibs
jntibs is offline
The Ram Ecodiesel 3.0 takes 10.5 quarts, so basically double a similar displacement gas engine.
  #41
Old 09-14-2014, 04:49 PM
jthorngate3's Avatar
jthorngate3
jthorngate3 is offline
Originally Posted by jdadamsjr
My wife complains about the mpg in hers too....
(but only when I drive it and it gets below her 21 mpg around dfw - so I reset it just before I coast into the garage )
but I can certainly attest to the 3.5 twin turbo being FUN in an Explorer Sport...
I get out of the 350 diesel which is not bad at all and jump into the wife's sport and WOW, I have to set the cruise because it WILL get away from you quickly...
and it's very nice that our only complaint in 20k+ miles is with the Microsoft Sync system !
I rented a truck while in Colorado a few weeks ago. Requested a fun50, but ended up with a dodge 1500. I can assure you, as I have sync in my car, that the uconnect they use is just the worst. It never understood what I said, I could barely tell what it said, and you had to download apps for it to work correctly, both with my phone and iPod.
  #42
Old 09-14-2014, 10:30 PM
super 6.8's Avatar
super 6.8
super 6.8 is offline
Wish they would announce the rpm's the hp and torque are made at. Have a running argument with a buddy that says the rpm's will be very high. I think not.
  #43
Old 09-15-2014, 06:30 AM
Tom's Avatar
Tom
Tom is online now
You're probably going to be half right. Horsepower is a product of torque and RPM, which means peak horsepower will almost always be at a high RPM. The only way that can be different is if torque drops rapidly as you get into high RPMs.
Torque on every turbocharged engine I've ever seen peaks very low. That's done because forced induction allows engineers to setup engines to build boost at low RPMs and provide outstanding low RPM power. If it's anything like the 3.5L engine you can expect peak torque to be before 3,000 RPMs with the majority of that available before 2,000 RPMs. Smaller displacement doesn't change that formula; the turbocharged 1.4L engine powering our Chevy Cruzes at work have peak torque at 2,500 RPM.
  #44
Old 11-12-2015, 09:16 AM
pmac150's Avatar
pmac150
pmac150 is offline
2.7 power
All I can say is that my 2.7 xlt CC with a 6inch lift, SCT Live wire Tune with 35" Tires is giving me plenty of HP, & Low end Torque and still giving me 22HWY. Yes step on it and it will lower to 17mpg. Having the SCT Live Wire LCD Screen shows me the boost levels. Mostly it needs around 5-8PSI of boost to move around town and on the HWY holding 65-70mph, it shows 3-5 psi. of boost. at 80mph it shows 9-11psi of boost, thats when you are using a lot of gas 17-18.
W.O.T. tops out at 19.8PSI. per turbo.
Again, 6inch Lift., 20" Rims, 35" tires. And still pulls like crazy
  #45
Old 11-12-2015, 12:18 PM
seventyseven250's Avatar
seventyseven250
seventyseven250 is online now
That is some great real-world info, and I think pretty relate-able for a lot of folks to how they would use their trucks.
Also great point about the increased boost required at higher speeds. We all know aero drag is a huge mileage killer, but it's nice to see someone who has put some effort into documenting it.
Reps sent!
Quick Reply: 2.7L EcoBoost 375HP and 375 lb/ft
