Systems 101: Designing a Custom Exhaust System for Your Truck
I am asking for an opinion on the design not the muffler. Frankly I am undecided on the muffler. So if you are unwilling to comment on the design I understand. Thanks
What vehicle are you designing your system for? Please let me know the model, year, engine and current exhaust setup (ie: is it still stock, what diameter tubing if it was altered, etc.).
on
Hey Matt, what do you think about this?
I have a 71 f-100 with a 351 cleveland engine. Nothing too hot, just edelbrock carb intake and cam.
Right now it has 2" dual off of stock manifolds, 22" glasspacks.
I like the way it sounds, but am wondering if the 2" pipes are flowing enough for ideal performance. The engine will never get revved above 5,500 rpm.
It's a daily driver, with some towing/hauling duty, and a lot of haul-*** duty. Basically my do everything pickup.
I would want it to sound aggressive and loud at the tail pipes, but keep quiet and mellow while cruising. The current system does a good job at that, but could be a little louder.
Here is a YouTube video I made of it.
Matt,
Does Flowmaster offer any type of system to replace the stock exhaust on a 1986 F150 SWB with 4.9L six cylinder, from the exhaust manifold back? The engine is stock other than having been converted to Duraspark ignition with recurved distributor. It still has the original 2 catalytic convertors, but no EGR or air pump.
My tastes are more towards the mellow sound, not too loud, but perhaps a little more free flowing.
Thanks!
Thanks!
Matt,
Thanks!
Thanks!
Matt,
I have 2011 f250 6.2. I have a CAI on the way and I want to do some exhaust mods for sound, power and economy. I have read a lot of post where there was a loss of mileage and power when exhaust mods are made. I believe the correct mods can help both power and economy. What would you recommend for this truck, cat back system or a few parts changed out? I also run the 87 performance/tow tune from five star. This is a weekend driver, 70% towing a four horse trailer or tractor.
Matt,
You should be fine as long as you are able to run an adequate amount of tail pipe, at least 12 inches, after the muffler.
#29
Matt
I have a 1990, F250, 351 that has a crack in the drivers side exhaust manifold.
Considering I got to replace the manifold I'm thinking about putting headers on it to maybe get a little more HP, MPG. Keep in mind I am completely open minded as to what would be best. I could just replace the manifold, or install headers and hook it up to what I have, or put headers on it and replace everything, or replace the manifold and change everything else. The air pump has been removed and the ports on top of the manifold have been plugged. As far as sound goes I don't care for anything loud but I want to easily hear it running. I would prefer to have duels coming out the back but it doesn't matter much. It looks like it be a little difficult getting one of the exhaust back over to to the other side. So again, the pipes can come out wherever would be best. Also, I don't mind if I need to get a muffler shop to do some of the work, especially when it comes to any bending. Please give me your opinion as to what would be best and maybe a recommendation as to which headers would most likely fit with out hammering and bending. Thanks, look forward to your reply.
#30
Matt
