thoughts on fuel milage
#31
#32
How's your FICM doing?
Does it maintain 47.5-49 volts?
With the latest flash you more than likely shot yourself in the foot because the latest flash is known to limit power. It's mainly done by limiting the "gatekeeper of fuel" known as the FICM.
This is easily resolved with a PHP FICM tune either Atlas 40 or Econo.
I had this very same problem on my truck as I had the latest flash from Ford which for me was VXDB1MZ. No matter what I did, even with Gearhead tunes, I never got more than 13-14 mpg. Once I got a FICM tuner and loaded the atlas 40, I rarely see less than 15-16 and as high as 18 mpg on the freeway.
Have you also performed the vgt relearn?
This is especially important after reflashing.
Are your hubs locked?
Turn to the left to free them and to the right to lock them.
Are you filling the tank up all the way?
Stupid question, but I wasn't....
I wouldn't get more than 80 miles before the needle started to move away past full. I started filling to the neck and now I get to 150 miles before it starts moving.
Where are you filling up?
Sometimes you just get some less than stellar diesel. Try switching stations and see if it helps.
#33
I have no idea about the vgt relearn, looks like something else to look up.
I have double checked the hubs, and they are unlocked.
As for how much fuel, since I live in Oregon, and in their infinite wisdom, it is against the law to fuel up my own vehicle, I am at the mercy of the fuel attendant and if they double check to see if it tripped early of not. In some ways not having to get out to fuel up is nice, but I am always hyper vigilant to make sure they don't put Gas in my Ex.
As for location, I always fuel up at the local Fred Meyers, they seem to have the best pricing around, and they have enough traffic that the fuel does not sit long in their storage tanks.
I may have to look into the FICM tuner, thanks for the information, and if you have links to where you got your setup, i would be grateful.
Thanks for the help.
#34
#35
#36
The attendants always freak out, but I tell them I know the law, and I am allowed by law to insist that I be allowed to fill my own tank. They have always said ok and stepped aside.
Stewart
#37
I checked the fan and all is well there.
That is good to know! I do always fuel up at the same place, and the folks there all know my Ex, so I very rarely have an issue. Lately, I have been letting them start the fueling, and then I hope out start talking with them and then finish it up myself. It ends up being the best of both worlds, plus I get the feeling they like to chat as most people just ignore them or get ticked off if it "takes to long" to get to their car...
After visiting Oregon a few times, and never letting them fill my tank, I decided to look it up and discovered it isn't against the law to fill your own tank. The attendants and most people who live there believe it is, but there is no law being broken if the customer insists on filling their own tank.
Stewart
Stewart
#38
I still suggest trying another station...
I thought it was trivial and wondered what difference it could make, but when I first got my '05 Excursion home, I kept filling up at a certain Shell and I kept getting 13-14 mpg even with the Atlas 40 and Gearhead tunes.
I switched stations and almost miraculously, I started getting better mileage 15-17 mpg.
#39
#40
Agree with you on this Tor, I'm now filling up at a truck stop and have gained a few tenths and the truck seems to run a little cleaner.
#41
I may try fueling up at the Safeway, but their attendants there are complete jerks. Dealing with them just makes me want to
#42
mileage
just curious if anything new has been discovered etc. I can't see why doing all those mods to improve the engine has decreased the mileage. I'd like to "bulletproof" mine one day but hate to see the mileage drop.
Also, i'm going to pull the trigger soon and use FICM Repair.com - Your Source for FICM Repair with the Atlas 40 tune. My FICM is getting/is weak.
#43
I just went through and cleaned the MAP and other sensors on Saturday. I need to do a full tank computation to really know how things are doing. I have been looking at a potential upgrade for the FICM programming. Hoping things are looking up with the cleaning and who knows if or when I will pull the trigger on the FICM program upgrade.
#44
Have you verified your front hubs are unlocked?
Do you reset the Lie-o-meter when you fill up?
More around town driving than highway normal?
My Lie-o-meter will show 13-14 MPG if I "just" drive to/from work, It's all local roads speed limit 20-25 and lots of 4-way stops. Once I get on a hiway it starts to climb quickly.
#45
Maybe, you got a tank of winter fuel?
