460 Coolant drain??
Yea the 460 has block drains (351 has em too), one each side of the motor.
Right side its just behind the motor mount, left side too but IIRC it is just a little bit farther back then the one on the right side.
Look like square head pipe plugs.....well they are pipe plugs and they tend to be brass from the factory but not sure if that is always the case.
I just did the reverse flush using the method described in link below. Worked great. I, too, would be worried about block leaks after removing block drains.
Cap-A-Radiator
Cap-A-Radiator
Cap-A-Radiator
Cap-A-Radiator
https://telegra.ph/HOW-TO-PROPERLY-R...G-SYSTEM-08-09
The following users liked this post:
01f350
10-08-2008 05:25 PM
gixxer1000
05-03-2007 09:32 AM
