Torque Pro Ford 6.7L Extended PIDs
#76
#77
#79
here is the list of PID's I assembled from the two optics on FTE plus the Torque pro app site..
anyone see something missing?
ECT is not working (truck just started, but the outside temp is 101, so It should show something.
rest match my hand entered pids from a few weeks ago. (displays side by side)
My apologies if I am in error or you have already corrected.
#80
Sorry I just read your post.
From my old memory and short answer.<O</O
The formula A*9/5 -40 is from the hexadecimal response from the binary bit "A" from PCM (hex to bin is "0" to "255"). To display a negative temperature ford make the bit "A" that equals 0 (zero) to show -40.<O></O>
<O</O
So the gauge temperature range is -40 to 205 degrees.<O</O
<O</O
If someone told me that it was “0” (zero) degrees Celsius on a thermometer, I would use the formula C*9/5+32 to know what it was in Fahrenheit. “C” is the temperature in Celsius, "A" is a hexadecimal value from the PCM.<O</O
<O</O
<O</O
#81
#82
I just posted in the wirelesS ODB topic a link to the one I bought.
If you scroll up a few messages you will see a set of gauges
The app lets you customize what things u want to watch, and what kind of display you want, round/square, with or without numbers.
Sort of create your own
#83
#84
As well as engine coolant and oil temp using numbers, not just a dial indicator.
#85
#87
Ok, so this topic has finally caught my attention. I ordered the el-cheapo chinese knockoff on ebay for a grand total of $8 including shipping. I then do what I do, and start learning as much as I can on the topic, and find reports of these knock off's causing problems with normal truck functions. I thought a code READer only read codes. How can it cause problems?
So, I go to the Torque-bhp webite, and find their list of favorite bluetooth readers, and decide I want something of higher quality, so I went ahead and ordered the OBDLink MX, because they say its firmware upgradeable, has battery saver, etc.
then I wander over to the OBDLink website, and peruse their forums, and see complaints of a 6.7 owner that says the reader caused transmission shifting problems. I also saw one of Sam's comments that one the cheapo's caused his truck to run rough too.
So, what's up? Who on here is running the OBDLink MX with Torque-Pro on a 6.7? Is it working?
#88
There are two CAN buse systems (HS-CAN and MS-CAN) on the ford and my next adapter I buy would access both, I believe that the MX can or is it the LX??
#89
#90
