stubborn 97
Old 06-17-2014, 06:55 PM
Stroked 89 CA's Avatar
Stroked 89 CA
Stroked 89 CA is offline
stubborn 97
hopefully i can get some help here
truck is back on the grind of not starting , been an on going problem , truck starts when it wants to , whether its first start of the day , or after it just drove 100 miles , some days it fires right up and other it keeps cranking with no start , some days when it does start , even at operating temps when i shut it off , let it sit for a minute and it wont start back up just keeps cranking and cranking , im lucky ounce in a while it barley catches and fires , only way to get it to start is with a pinch of ether , i know my gp system is not working properly , but at these temps there not needed anyways , was recently at a local diesel shop and the ford dealer , between the two they told me it has good compression , good fuel pressure and passes a buzz test , dealer said the injectors could be binding up? truck does not miss a beat when running , no cel , everything works as it should , wts light all that stuff works , its got a new motorcraft cps , still wont start with the <acronym title="Injector Pressure Control">icp</acronym> unplugged , just throws a cel , i don't have a way to watch <acronym title="Injection Pressure Regulator">ipr</acronym> cycle and the tin nut is tight ,
codes its throwing are
p0113 - intake air temp circ low input
p0603 - internal ctrl mod KAM error
p0478 - exhaust press ctrl valve high input
p0470 - exhaust back pres sens circ error
- video of what it does
Old 06-17-2014, 07:42 PM
96ford250's Avatar
96ford250
96ford250 is offline
Sounds like your EBPV is stuck/sticking shut for starters the other codes I'm not so sure.
Old 06-17-2014, 08:07 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
My guess its your IPR getting old and sticking.
Old 06-22-2014, 11:15 PM
Stroked 89 CA
pretty sure my ebpv is open , its unhooked anyways , i am leaning towards the ipr also but i need to get it on a scanner to check duty cycle
anybody else?
torquemeister
13
06-16-2020 09:49 AM
Volkskid
10-13-2014 09:25 PM
DougH000
48
10-08-2013 07:50 AM
lablue96
02-24-2013 01:20 PM
saleen1996
13
07-27-2007 10:33 PM
Quick Reply: stubborn 97
