The "wrench"
The "wrench"
08 450
So I drove home from a jobsite tonight about 150 miles pulling a trailer , truck ran like a top.
The last couple of miles to home is uphill , the wrench symbol came on my dash and I lost power but made it home.
I shut truck off and had a look under the hood but didn't see anything , started it back up and the wrench was gone?
So what kinds of issues can the wrench light be pointing out?
If you are getting laggy acceleration, it means that the computer isn't seeing the boost, or maybe there isn't boost.
Because you said there is black smoke, that probably means the boost isn't there to burn up the fuel.
So either the turbo isn't running right, or there is a problem with air flowing. Air filter good? What are you seeing for turbo PSI while driving?
If the PSI looks good, chances are it's an issue with too much EGR running into the intake, eliminating usable fresh air.
