Engine stalls
Old 06-14-2014, 05:23 PM
Yaz-Lariat's Avatar
Yaz-Lariat
Yaz-Lariat is offline
Engine stalls
I recently changed the phasers, tensioners, chains and guides on my 04, 5.4. The engine sounds perfect before and after warming up while at idle. The problem I'm having is the engine stalls when I put it in drive or come to a complete stop. The vehicle seems to struggle a little while driving up a hill.
I have driven more than 50 miles, the check engine light hasn't come on, I reset the computer by removing the negative lead from the battery. I cleaned the MAF sensor, throttle body, and both VCT solenoids are new.
Any advised will be appreciated.
Old 05-20-2015, 03:27 PM
06mikes's Avatar
06mikes
06mikes is offline
vct solenoid
Did you put oem solenoids or aftermarket? The aftermarket vct solenoids will cause this issue. Also with it going up hill and having issues could be fuel filter
buckmarkford
1999 to 2016 Super Duty
13
08-11-2016 03:54 PM
cmhwv1988
Modular V8 (4.6L, 5.4L)
05-30-2015 08:42 PM
5.0stang
2004 - 2008 F150
08-09-2011 10:38 PM
NuDog
03-07-2004 04:39 PM
redranger1
02-24-2003 12:18 PM
Quick Reply: Engine stalls
