Project Daily Driver, 1990 F250
Hello everyone! Amazing forum! Have learned so much and had so much help since joining!!! I have had a bunch of Ford trucks, mostly 1/2 ton. I want to get a bigger boat soon but need more than a 1/2 ton truck. I didn't want to spend 50-60K for a new 3/4 or 1 ton truck or 30K for a used 3/4 or 1 ton truck. So last fall I started looking for a older truck to restore and I finally found one on 04/19/2014. So here it is!! 1990 F250 Super Cab XLT Lariat 2wd 460/auto Red-n-Camp Conversion truck with 69K original miles!!! Here are the pics of how I got it!
That's an impressive before and after collection. Is the tailgate an aftermarket replacement or from a junk yard? Mine's in bad shape and I am planning on having mine repainted eventually. I didn't know if it'd be cheaper to repair the old one or get an aftermarket replacement.
Did you paint it yourself? What did you do with the white in the door jams and inside the engine compartment?
Rachet, I painted the door jambs, tailgate jamb, inside gas doors myself. I did not do under the hood or the bed. The bed I'm just going to do a spray in liner. I don't have access to a spray booth so I had the local maaco paint the truck for $600.00, but I masked the jambs myself and disassembled the truck in their parking lot (lights, mirrors, trim, etc) so the paint job came out good.
1. How far did you go in terms of sanding? I see that you sanded alot where what I think were decals were. Were you trying to go to bare metal or just trying to get it rough enough to stick?
2. I'm assuming that you removed all the trim, bumpers, lights, etc. Is that right?
3. How much did you tape, did you cover the windows completely? Did you remove the trim around the windows?
4. Was this all hand sanded or did you use a machine?
Okay, I want to ask more about the paint process that you went through. I'm pretty much a rookie but I want to do basically what you've done, prep my truck and get a low cost paint job. So if you don't mind, here are my questions.
