About that time to go to electric fuel
Old 06-10-2014, 12:26 PM
jchosler's Avatar
jchosler
jchosler is offline
The other day I found a substantial fuel leak coming from the valley. I looked at it closer and determined its from the machanical lift pump. I told myself I wouldn't go to electric fuel till this one tanks a dump, now is as god a time as any.
My initial research shows Bullydog, barnonediesel, CPR, and Beans.
I have read a number of threads that vouch for all of them so I was wondering what you guys thought was the best value for the money?
Thanks
Old 06-10-2014, 01:11 PM
Hussler's Avatar
Hussler
Hussler is offline
Check out Strictly Diesel's fuel kits out of Arizona. Believe this is the route I'm going when wife gives permission. At least another option to consider.
Driven Diesel COMPLETE OBS Fuel System
Old 06-10-2014, 01:18 PM
Clay H's Avatar
Clay H
Clay H is offline
Contact Dave at vegigarage, he has a slick E-fuel setup he just put a kit together for. I dont see it on his website but I know a guy here who just put it on and he said its top notch.
Its not related to vegi at all other than the OBS has to have E-fuel before converting to vegi so he made a kit.
http://www.veggiegarage.com/categori...=21803&type=pr
Old 06-10-2014, 01:19 PM
Clay H's Avatar
Clay H
Clay H is offline
Old 06-10-2014, 01:48 PM
jchosler's Avatar
jchosler
jchosler is offline
That looks like a good kit. I noticed that both this kit and the Beans kit uses Bosch pumps but Beans is good up to 250 cc injectors while this is good for 160cc. Beans right now is a little cheaper. Anyone have experiance with the Beans?
Old 06-10-2014, 01:50 PM
jchosler's Avatar
jchosler
jchosler is offline
The striclty diesel is prettier tho
Old 06-10-2014, 02:57 PM
fordman67's Avatar
fordman67
fordman67 is offline
Personally.i think the beans is over rated and i basically copied the driven kit with an aeromotive regulator and gsl 392 pump.we will see soon how it works
Old 06-10-2014, 03:05 PM
Clay H's Avatar
Clay H
Clay H is offline
WOW, you'll save a ton of money going through Vegigarage I think.
Old 06-10-2014, 06:35 PM
fordman67's Avatar
fordman67
U work there or something?
Old 06-11-2014, 01:30 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
If you have the cash the Strictly / Driven Diesel kit is the way to go. Without a doubt the best kit available. I have the top end kit. The only issue I had with it was the driver side rear fuel fitting wouldn't get tight in the position I wanted it in. Doesn't leak but its not as tight as I would like.
Old 06-11-2014, 08:04 AM
jchosler's Avatar
jchosler
jchosler is offline
Is this the one you have?
Driven Diesel OBS RACE Fuel System
Ive been talking to there help department and it looks like I will be doing the larger kit as well just in case I go to larger injectors compared to my 160cc that I have now
Old 06-11-2014, 10:35 AM
Clay H's Avatar
Clay H
Clay H is offline
No hes simply a good guy that I support.
You have a problem with me offering this suggestion to the OP?
Old 06-11-2014, 10:39 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
I have the kit, this was a few years ago now, that addresses the plumbing from an existing or customer provided pump and filter setup. They didn't have the full system they offer now back then. What I call the top end kit came with just the fittings, lines, regulator etc to eliminate the fuel bowl. No hose or anything to feed and return from the pump and filter.
I really can't say that you will ever need the race kit. I kinda doubt it. But thats up to you.
Old 06-11-2014, 11:59 AM
fordman67's Avatar
fordman67
Heck no.if you like him and have experience that is positive then by all means.
its just not a household name generally and its not exactly what i think of as a general rule.
we need more good suppliers with good products and stellar customer service.sure are plenty of less than good ones.
sorry to op for deraik
Old 06-11-2014, 03:38 PM
nomad221's Avatar
nomad221
nomad221 is offline
pr</acronym>
Do you have a link to the other members write up ?
Quick Reply: About that time to go to electric fuel
