cab swap - now no power in cab
Long story short swaped cabs 95 f250 truck with a 92 f150 cab. swaped dash boards along with wiring harness. Only thing that i left was the power door amd window harness.
when i first tried it everything seemed to work. 10 sec later everything died.
now the switchs are controling everything but what they are suppose to. when key is off service engine light comes on.
blower switch turns the glove box light on.
will not crank
Any ideas???????? already replaced key switch checked wireing over and over. all fuses have 12v inside and outside fuse boxs
will not crank
I am seeing lots of repsonces to ground issues I am going to adress that as soon as I can and see what happens.
With the wiring I have swapped the entire harness from my matching truck to the donor - the only wires that I left where the power Windows and locks anything that went directly to the firewall I have swapped out. All of the wires should match
some update
Okay I checked the grounds and so forth - now the fuel pump will cycle with the key. CEL comes on with the key. Also the dashboard back lights work when the key is turned to the crank postion. Truck will not crank though. Also one time I was able to turn the key switch very lightly and get the blower to turn on. Now I cannot (2 key switchs so far, plus the original)
Now the lights will not turn on with the key switch. I have checked all fuses and swapped relays just to see what happens no luck there
Received 3,108 Likes
on
I will check my grounds again - even add'ed some. I thought it would be easy after i swapped the harness's. I think putting the cab back on was easier then figuring this out.
I will say i made progress in the sense that, when something works it is working. What i mean is i am no longer turning the glove box light on with the blower switch. So i may have somewhere have a bad connection or weird wire connection. Things are just not working, there at least not doing things they shouldn't be.
Any more advice is more then welcome!
BTW Thank you very much for the help so far!
Thank you!
Now it will start, runs lights work on the dash and the blower all works.
Radio is still dead though
Also the turn signals are screwy BUT none of the lights are hooked up.
It was all ground issue's!!!!
Far as the radio I have power to it, I ran a ground from the ground wire and still nothing (aftermarket radio)
on
Goldman97F250
05-08-2018 04:43 PM
1978fordf250
07-26-2010 08:31 AM
new f250 owner
03-23-2005 08:17 AM
