Another Dana 60 swap.
Old 06-06-2014, 10:11 PM
thewestie's Avatar
thewestie
thewestie is offline
I plan on New springs. Was going to talk to local spring shop. There nice and will take time and let me.ask a.bunch of dumb questions and get what he suggests. I was thinking a littlle lift.
Old 06-06-2014, 10:13 PM
thewestie's Avatar
thewestie
What's the rsk setup?
Old 06-06-2014, 10:17 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Reverse shackle kit
Some reading here with pics
https://www.ford-trucks.com/forums/1...l-fab-rsk.html
Old 06-07-2014, 06:59 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
Just putting the D60 under it lifts it a little. You need the original 4" blocks in the back to make it set like a F350. If you don't go with the RSK, DEFINITELY change to the F350 springs. Did you notice the springs in my pic? DON'T do that! The ride sucks! They will get you by in a pinch, but that's it. I will be changing them real soon before my kidneys completely fail!
Old 06-08-2014, 01:36 PM
thewestie's Avatar
thewestie
I have the 4" blocks. It looks like I'm running the stock springs for a while. I have to change the rear end to match the fronts gear ratio. At that point ill change all springs.
Old 06-08-2014, 04:21 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
thewestie, I'm making the swap and then doing a RSK later. All my research says to use the F350 leaf springs, steering pieces and pitman arm when you do. I've already put the F350 blocks in mine.
Old 06-10-2014, 10:00 AM
thewestie's Avatar
thewestie
Has anyone used junk yard springs. What's the difrence in 1.43 and 2.03 springs?
Old 06-10-2014, 11:40 AM
eakermeld's Avatar
eakermeld
Where did you get these two numbers from?
Old 06-10-2014, 01:54 PM
thewestie's Avatar
thewestie
From car-parts.com. they offer the two different thicknesses
Old 06-10-2014, 05:39 PM
eakermeld's Avatar
eakermeld
Ok, the thicker of the two are diesel springs. You don't want them. Rough ride. Go here and prowl around. It will show you some stuff about springs.
Ford Truck F Series Light Duty Truck Leaf Spring Hangers,Ford Truck F Series Light Duty Truck Leaf Spring Shackles, Complete Suspension Kits-AutoandTruckSprings.com
Old 06-13-2014, 05:04 PM
thewestie's Avatar
thewestie
Well the 60's in. I know with the 250 pitman arm I'll have reduced stering radius. My problem is I think I put it tyrod on arm when clocked wrong turns great to right. Not so good to left. Can I drop tie rod at arm and rotate wheel one turn to the left?
Is there a procedure for doing this in the dirt ?
Thanks.
Old 06-14-2014, 08:15 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
I haven't done this myself yet, but this is what i think I would do:
The pitman arm can only be clocked on the steering box shaft at one angle. I'd disconnect the steering linkage, and center the steering box by turning the steering wheel all the way to the left, then all the way to the right, then half ways between those two points, regardless if the steering wheel is straight or not.
Then I'd make sure by tires were parallel to eachother and then also facing straight ahead.
I'd adjust the steering linkage (not the piece connecting the two wheels) lengthwise to fit the pitman arm. And if necessary, loosen and reclock the steering wheel on its shaft.
  #28
Old 06-14-2014, 08:20 AM
thewestie's Avatar
thewestie
That's the what I was thinking. Doing household hazardous waste day then under the truck.
  #29
Old 06-14-2014, 10:23 AM
thewestie's Avatar
thewestie
That worked. Now it hits right stop but not left. I think shortening the tie rods will fix that.
Its almost on the ground
  #30
Old 06-14-2014, 05:18 PM
thewestie's Avatar
thewestie
Well that certainly does bounce you around a bit
Quick Reply: Another Dana 60 swap.
