If he has issues with trans tunnel clearance and shifter location already, what does moving the whole gearbox back 7" do for him?
$1,500+ seems like it could be better used to fit the truck to a 5-speed than make a 4 speed into an 8.
Just a thought. If the T18 is "thinner" up top than the ZF5 then moving it rearward 7" it still might be smaller than the ZF5. I don't know, but it's just a thought of a different way to do it.
The 18/19 cast iron cases certainly are more compact than the ZF alloy housing.
Darn things are bulletproof too.
I'm sacrificing a some mileage already. Were either of those transmission overdrive? I might consider a four speed overdrive in place of the ZF. I understand durability, but I'd like to keep it around 15mpg if I can. I'm only getting low 20's with the 2.4L.
I'm also a bit concerned with weight. I am estimating the 331 at about 475 pounds. The torsion bars are only 33% stronger than stock. I really don't want to be changing them annually.
Yeah, the NV case (also case iron) is more compact than a ZF too.
There were some lighter duty NV3500/3550 used in 1/2 ton dodge trucks and jeeps. Not sure about their durability, but I would guess they are somewhat compact compared to a ZF.
You could always use an aluminum block and titanium rods...
RW- I agree the ZF is a better option. Since the drive shaft is custom, I still need a weight comparison between the NP208 and the BW1356 transfers. As long as both are manual shift variants.
I'd like a load cell, but the old bathroom scales work for most things. I'm going to weigh the heads, intakes, water pumps, and even carbs to determine how much weight the aluminum diet has shed from Dad's truck.
