Soft brake pedal
Soft brake pedal
Hi I just replaced my booster and master cylinder, I bled the brakes until the new fluid came out and continued until I had good pedal now after runnning around for about 15 miles the pedal is soft When I bled them I started at the passenger rear and worked my way to the drivers front. Thank You for any help.
Um, what do you need to be "set up" to bench bleed an MC? Shoot, you can do it while it's installed. And yes, you NEED to do it, and now you'll also need to re-bleed at the wheels. What year truck (good to include in your opening post, and NO your signature does not count)? If it has ABS, you should bleed the RABS valve after doing the rears and before the fronts.
Frank250Tank
12-20-2016 10:07 AM
daddylee100
30
07-26-2016 12:53 PM
IDIDieselJohn
21
10-18-2015 06:38 AM
sam03rc
32
05-05-2013 12:02 AM
