SUMMER CHAT 2014
#151
stock dodge had 1/2 inch studs for a lot of years, where ford and chevy were 9/16 inch studs. I have never put dodge wheels on a ford but I do know that putting ford wheels on a dodge is tough as the nuts bed too deep in the taper of the rims so you have to find wide flange nuts so they will work. the dodge rims might be too tight to go over the 9/16 inch studs so I would check them before I had the tires mounted and balanced.
I think the alloy Dodge wheels look OK but the steel in chrome look like crap. That is why I bought the power coated stock Dodge. I wanted to go back to stock offsets. It drive better with that set up.
Ray, good to hear from you. More pictures of you new toy or project. Yea things are going forward. Will have plans & permits by years year end, maybe much sooner. I heard from my Architect & he is about done with his house & said things will free up in a month. So I may have them sooner than I really want them. But that is OK too.
#153
#155
Once you get five posts on the Arizona Chapter boards, feel free to request membership if you wish. Not mandatory. If my memory is correct you did awhile back request to join.
Would really enjoy having you, we always want members who are active on our board.
#157
I stand corrected. You are a member. I apologize. as the new Chapter Leader I haven't seen you here so I was assuming you were new.
Thanks for posting hope you will stick around more.
#158
on
A town nearby called Vernon I just found out has recently caught fire and has 2000 acres on fire. Kinda scary because we can see the smoke from where we are and Vernon is less then 45 mins away. No idea on the containment but to me it looks pretty bad.
Trav
#159
Received 3,697 Likes
on
#160
It is scary non the less. It is a long ways from us in Ash Fork but the thought of how dry it is is just scary. The threat of fire is what made us take the action we have in bringing in professionals to trim our trees clean up all the dead & down.
We have seen areas in the Sierra Nevada mountains where the Forest Service went in & trimmed all the trees in an area. A year later a fire went through there & very little was damaged. It just burned the grass left light charring on some of the trees.
We have been fortunate in our area there haven't been fires of any degree for sometime. But you never know.
#161
on
We still will be holding the get together today even with the fire nearby.
Trav
#162
on
Howdy az gang just got an update. It is over 5K acres and 0% containment. Yes Bart you are correct it is moving northeast but you are wrong that it is a long way from me. I do not live in the town of snowflake I live outside of snowflake. I am actually in between snowflake and Concho. It takes me 45 mins the long way to get to Vernon driving 50 MPH. So far my mom is keeping updated on it and will get word fast if the Cedar hills residence area (that's my area) will be evacuated. As of right now we look to be fine but winds change and fires are very very weird. If it does come our way it will more then likely take our place out being it is so close to the mountain (I live 5 miles of dirt road making it close to Mesa Redonda). Will try and keep y'all updated.
Trav
Trav
stay safe!
#163
Trav
Trav
#165
Only 111 here Bill.
Have to wait until Thursday to go up to the retreat. Got our other generator so we now have two 2000w inverter generators with a parallel kit. It will give us a solid 26.6 amps. Plenty to run everything in our trailer. As long as we don't try running the A/C & Microwave at the same time. But we can't do that here plugged into Mohave Power. Because it will blow the trailers main breaker.
