Running Lights Wire Color..
#31
Everything is NON LED lighting that I am working with here Crewcabber...
So I am going to run power to the yellow wire just before it goes into the relay, and if everything works fine, then Ill know Subford nailed it and its a bad fuse link. Then I can just replace the fuse link when I get time. If that doesnt work then I will do Crewcabber's idea and tap into the license plate lighting as a temp fix for the trip. One of those two should get me a temp fix for tomm... Hey Crewcabber, how do I shoot you a private message on here...
